ROG Strix G15 G512LI RAM Replacement
    1. ROG Strix G15 G512LI RAM Replacement, Removing The Cover: step 1, image 1 of 1
      • Remove the screws from the compartment cover, As show in the diagram, unscrew the screws labeled "A" first. before unscrewing "B", Don't remove screw "B" from the cover.
      Ask FixBot
    2. ROG Strix G15 G512LI RAM Replacement: step 2, image 1 of 1
      • Remove the panel, but be careful as there are 2 cables linking the RGB light bar to the motherboard, carefully and gently detach them from the motherboard and lift the panel.
      Ask FixBot
    1. ROG Strix G15 G512LI RAM Replacement, RAM Replacement: step 3, image 1 of 2 ROG Strix G15 G512LI RAM Replacement, RAM Replacement: step 3, image 2 of 2
      • Locate the RAM Slots.
      • If you are replacing your RAM, take the RAM out and insert a new stick at a 30 degree angle, and push down the RAM module until it clicks into place.
      • If you are adding another module into the system, make sure it is compatible with the laptop before installation
      Ask FixBot
2 other people completed this guide.
June
617 Reputation
3 Guides authored
1 Guide Comment
how to fix the light bar i have one side wont light on
fethallah - Reply Share
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 118
All Time: 7,334
