RK5 PLUS VR Headset Headband Replacement
  1. RK5 PLUS VR Headset Headband Replacement, Headband: step 1, image 1 of 3 RK5 PLUS VR Headset Headband Replacement, Headband: step 1, image 2 of 3 RK5 PLUS VR Headset Headband Replacement, Headband: step 1, image 3 of 3
    • Place the headset right side up and facing you on a flat surface.
    • Gently detach the velcro straps from the top, left, and right sides of the headset and set them aside.
    Ask FixBot
  2. RK5 PLUS VR Headset Headband Replacement: step 2, image 1 of 1
    • Remove the white headband adjustment part and carefully pull it off of the three straps.
    Ask FixBot
  3. RK5 PLUS VR Headset Headband Replacement: step 3, image 1 of 3 RK5 PLUS VR Headset Headband Replacement: step 3, image 2 of 3 RK5 PLUS VR Headset Headband Replacement: step 3, image 3 of 3
    • To access the straps that need to be replaced, remove the padding around the visual lenses of the headset.
    • To do this, use your hands to detach the plastic frame between the padding and the lenses.
    • If you need help getting started, use a spudger or opening tool and undo the clips holding the plastic frame.
    • Unhook the old straps from the sides of the headset.
    Ask FixBot
  4. RK5 PLUS VR Headset Headband Replacement: step 4, image 1 of 3 RK5 PLUS VR Headset Headband Replacement: step 4, image 2 of 3 RK5 PLUS VR Headset Headband Replacement: step 4, image 3 of 3
    • Reattach the new velcro straps to each of the white hooks.
    • Make sure the straps are securely attached to the hooks before moving on to the next step.
    Ask FixBot
  5. RK5 PLUS VR Headset Headband Replacement: step 5, image 1 of 2 RK5 PLUS VR Headset Headband Replacement: step 5, image 2 of 2
    • Reattach the plastic frame with the padded back onto the headset.
    • Make sure the padding is properly aligned and clicked into place.
    Ask FixBot
  6. RK5 PLUS VR Headset Headband Replacement: step 6, image 1 of 3 RK5 PLUS VR Headset Headband Replacement: step 6, image 2 of 3 RK5 PLUS VR Headset Headband Replacement: step 6, image 3 of 3
    • Reattach the top band into the top hook of the headset.
    • Take the other sides of the velcro straps and hook them into the white headband adjustment part.
    • Check that the straps are properly aligned and securely attached to the headband adjustment part.
    Ask FixBot
  7. RK5 PLUS VR Headset Headband Replacement: step 7, image 1 of 1
    • You have successfully replaced your damaged headbands for the RK5 Plus VR headset!
    Ask FixBot
Faraaz Abdul
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 621
