RIDGID R860052 Switch Assembly Replacement
    1. RIDGID R860052 Switch Assembly Replacement, Switch Assembly: step 1, image 1 of 2 RIDGID R860052 Switch Assembly Replacement, Switch Assembly: step 1, image 2 of 2
      • Remove the battery from the drill before you begin.
      • Use a T10 Torx screwdriver to unscrew the ten screws on the information label side of the drill.
      • These ten screws are 19 mm long.
      Ask FixBot
    2. RIDGID R860052 Switch Assembly Replacement: step 2, image 1 of 1
      • Lift off and remove the cover with the informational label.
      Ask FixBot
    3. RIDGID R860052 Switch Assembly Replacement: step 3, image 1 of 3 RIDGID R860052 Switch Assembly Replacement: step 3, image 2 of 3 RIDGID R860052 Switch Assembly Replacement: step 3, image 3 of 3
      • Remove the switch assembly, chuck, and motor from all drill covers.
      • Check if all wires are connected to the switch assembly and motor as illustrated in the image.
      Ask FixBot
    4. RIDGID R860052 Switch Assembly Replacement: step 4, image 1 of 2 RIDGID R860052 Switch Assembly Replacement: step 4, image 2 of 2
      • To replace the switch assembly, desolder the black and red wires and replace with a new switch assembly.
      • Be aware of the heat level of the metal part on the soldering tool.
      Ask FixBot
Anna Wu
273 Reputation
2 Guides authored
UC Davis, Team S18-G4, Lore Winter 2019 Member of UC Davis, Team S18-G4, Lore Winter 2019
UCD-LORE-W19S18G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 819
