RIDGID R84015 X2 Disassembly
Views: 15K
View statistics:
Past 24 Hours:
2
Past 7 Days:
29
Past 30 Days:
112
All Time:
14,562
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow these steps to disassemble the plastic casing of the RIDGID R84015 X2 power drill.
Tools
    1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: step 1, image 1 of 2 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: step 1, image 2 of 2
      • Remove the backplate.
      • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
      Ask FixBot
    2. RIDGID R84015 X2 Disassembly: step 2, image 1 of 1
      • Remove the drill handle.
      • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
      Ask FixBot
    3. RIDGID R84015 X2 Disassembly: step 3, image 1 of 2 RIDGID R84015 X2 Disassembly: step 3, image 2 of 2
      • Remove the gear casing from the body.
      • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
      Ask FixBot
    1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: step 4, image 1 of 1
      • With your drill taken apart, move your attention to the trigger and forward reverse switch.
      Ask FixBot
    2. RIDGID R84015 X2 Disassembly: step 5, image 1 of 1
      • Check to see that the forward reverse switch isn't broken.
      • NOTE: small tab on trigger fits into groove on forward reverse switch
      Ask FixBot
    3. RIDGID R84015 X2 Disassembly: step 6, image 1 of 1
      • With the battery attached, check that the wires work when the trigger is pulled.
      • Put multimeter wires here.
      • If wires work and drill doesn't, the problem is with the motor.
      Ask FixBot
    4. RIDGID R84015 X2 Disassembly: step 7, image 1 of 1
      • Make sure plastic is not broken and switch is not stuck.
      Ask FixBot
Finish Line
2 other people completed this guide.
Brian
100 Reputation
1 Guide authored
Cal Poly, Team 15-48, Garner Spring 2010 Member of Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Members
60 Guides authored
1 Guide Comment
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - Reply Share
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 112
All Time: 14,562
