Up to 20% off select tools
RIDGID R32104 Trigger Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
79
All Time:
957
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the trigger in your Worm Drive Saw won’t respond when pressed or appears to be broken, use this guide to remove and replace your trigger switch and trigger. All you need are the standard Phillips 2 Screwdriver and Torque 20 Screwdriver, in order to remove the two types of screws involved with this replacement.
    1. RIDGID R32104 Trigger  Replacement, Trigger: step 1, image 1 of 1
      • Turn off your saw and unplug before starting.
      • Place the Worm Drive Saw down and adjust the base plate, so that way the main housing assembly and handle set is easily accessible.
      Ask FixBot
    2. RIDGID R32104 Trigger  Replacement: step 2, image 1 of 2 RIDGID R32104 Trigger  Replacement: step 2, image 2 of 2
      • Using the Torque 20 screwdriver, remove the twelve 3/10 cm screws holding the handle set together.
      Ask FixBot
    3. RIDGID R32104 Trigger  Replacement: step 3, image 1 of 2 RIDGID R32104 Trigger  Replacement: step 3, image 2 of 2
      • Carefully remove the handle set from the main housing assembly.
      Ask FixBot
    4. RIDGID R32104 Trigger  Replacement: step 4, image 1 of 3 RIDGID R32104 Trigger  Replacement: step 4, image 2 of 3 RIDGID R32104 Trigger  Replacement: step 4, image 3 of 3
      • Place the Worm Drive Saw on its side to help remove the trigger.
      • Use the Torque 20 screwdriver to remove the single 3/10 cm screw that attaches the trigger switch to the handle set.
      Ask FixBot
    5. RIDGID R32104 Trigger  Replacement: step 5, image 1 of 2 RIDGID R32104 Trigger  Replacement: step 5, image 2 of 2
      • Use the Phillips 2 screwdriver to remove the four 3/10 cm screws holding the trigger and four wires, from the main housing assembly, in place.
      Ask FixBot
    6. RIDGID R32104 Trigger  Replacement: step 6, image 1 of 1
      • Remove the trigger switch and trigger from the handle set.
      Ask FixBot
2 other people completed this guide.
Author
with
Lucas Pimentel
1,037 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 79
All Time: 957
