RIDGID R2740 Motherboard Replacement
  1. RIDGID R2740 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Unplug your device before proceeding..
    Ask FixBot
  2. RIDGID R2740 Motherboard Replacement: step 2, image 1 of 1
    • Orient the sander so the Air Guard logo is facing you.
    • Remove the single Torx TR20 screw.
    Ask FixBot
  3. RIDGID R2740 Motherboard Replacement: step 3, image 1 of 2 RIDGID R2740 Motherboard Replacement: step 3, image 2 of 2
    • Orient the device with the left side face up.
    • Using a Phillips #1 bit, unscrew the 3 screws which hold the internal casing in place.
    • Gently remove the belt.
    • Using the Torx TR10 bit, unscrew the 10 screws which hold the external casing in place.
    Ask FixBot
  4. RIDGID R2740 Motherboard Replacement: step 4, image 1 of 1
    • Gently pull up on the motherboard chip set, pulling it directly from the device.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 24
All Time: 1,024
