RIDGID R2740 Ball Bearing Replacement
  1. RIDGID R2740 Ball Bearing Replacement, Ball Bearing: step 1, image 1 of 2 RIDGID R2740 Ball Bearing Replacement, Ball Bearing: step 1, image 2 of 2
    • Orient the belt sander so that the AirGuard Technology logo is facing you.
    • Remove the nine 19mm, two 51mm and one 32 mm screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
    Ask FixBot
  2. RIDGID R2740 Ball Bearing Replacement: step 2, image 1 of 1
    • Remove the assembly armature from the belt sander.
    • You may need to wiggle the assembly armature to remove it from the belt sander.
    Ask FixBot
  3. RIDGID R2740 Ball Bearing Replacement: step 3, image 1 of 2 RIDGID R2740 Ball Bearing Replacement: step 3, image 2 of 2
    • Use a hammer to pry the ball bearing from the assembly armature.
    • The ball bearing can be somewhat difficult to remove. You may need to apply WD-40 before removal.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 38
All Time: 1,566
