RICATECH-RTT22 Turntable Belt Replacement
    1. RICATECH-RTT22 Turntable Belt Replacement, Belt: step 1, image 1 of 3 RICATECH-RTT22 Turntable Belt Replacement, Belt: step 1, image 2 of 3 RICATECH-RTT22 Turntable Belt Replacement, Belt: step 1, image 3 of 3
      • Remove the arm holder by moving the needle to the side and lifting up.
      • Remove the rubber pad by lifting it up.
      Ask FixBot
    2. RICATECH-RTT22 Turntable Belt Replacement: step 2, image 1 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 2, image 2 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 2, image 3 of 3
      • Flip over the record player. There should be screws (10mm phillips head) on the back.
      • Use your phillips head screwdriver to remove each screw (keep them in a safe place for later).
      Ask FixBot
    3. RICATECH-RTT22 Turntable Belt Replacement: step 3, image 1 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 3, image 2 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 3, image 3 of 3
      • There will be three wires connecting the top to the bottom. Disconnect them carefully.
      • Put the back component of the record player to the side.
      Ask FixBot
    4. RICATECH-RTT22 Turntable Belt Replacement: step 4, image 1 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 4, image 2 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 4, image 3 of 3
      • Use your phillips head screwdriver to remove the three screws (8mm phillips head) holding the motor in place.
      • Keep in mind that there is some pressure on the motor, since the belt holds together the motor and turntable.
      Ask FixBot
    5. RICATECH-RTT22 Turntable Belt Replacement: step 5, image 1 of 2 RICATECH-RTT22 Turntable Belt Replacement: step 5, image 2 of 2
      • Unbolt (6mm bolt) the turntable from the housing using your wrench.
      • Since the turntable is designed to rotate, make sure the other side of the pin is kept from rotating while unbolting.
      Ask FixBot
    6. RICATECH-RTT22 Turntable Belt Replacement: step 6, image 1 of 2 RICATECH-RTT22 Turntable Belt Replacement: step 6, image 2 of 2
      • Carefully removed the rubber band from around the motor and extract the turntable from the device.
      Ask FixBot
    7. RICATECH-RTT22 Turntable Belt Replacement: step 7, image 1 of 1
      • Remove the damaged belt. Place the new belt around the turntable.
      Ask FixBot
    8. RICATECH-RTT22 Turntable Belt Replacement: step 8, image 1 of 2 RICATECH-RTT22 Turntable Belt Replacement: step 8, image 2 of 2
      • Follow the instructions backwards to reassemble the record player.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,152
