REV Robotics Control/Expansion Hub XT30 Connector (Male/Female) Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
30
Past 30 Days:
136
All Time:
1,462
Comments: 4
4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to replace the XT30 power in / out connectors on a REV Robotics Control Hub or Expansion Hub, commonly used by FIRST® Tech Challenge (FTC) and FIRST® Global Challenge (FGC) teams.
Parts
Tools
    1. REV Robotics Control/Expansion Hub XT30 Connector (Male/Female) Replacement, Remove 4 screws at the back of the control hub: step 1, image 1 of 1
      • There are Phillips #00 screws located at the back of the Control Hub. Two are located behind a sticker, which you will have to poke through or peel off.
      Ask FixBot
    2. REV Robotics Control/Expansion Hub XT30 Connector (Male/Female) Replacement, Pry open Control Hub Case: step 2, image 1 of 3 REV Robotics Control/Expansion Hub XT30 Connector (Male/Female) Replacement, Pry open Control Hub Case: step 2, image 2 of 3 REV Robotics Control/Expansion Hub XT30 Connector (Male/Female) Replacement, Pry open Control Hub Case: step 2, image 3 of 3
      • After unscrewing the four Phillips #00 screws, you will need to pry open the plastic housing of the case to expose the circuit board.
      Ask FixBot
    3. REV Robotics Control/Expansion Hub XT30 Connector (Male/Female) Replacement, Isolating the Board: step 3, image 1 of 1
      • After prying off the plastic case, you should be able to freely remove the board along with the piece of plastic it rests on. Remove the board from this plastic, exposing the electronics.
      Ask FixBot
    4. REV Robotics Control/Expansion Hub XT30 Connector (Male/Female) Replacement, Flip The Board Over locate XT30 Through Hole Connectors: step 4, image 1 of 1
      • After isolating the board flip the board over and locate the XT30 Through Hole Connectors.
      Ask FixBot
    5. REV Robotics Control/Expansion Hub XT30 Connector (Male/Female) Replacement, Desolder and resolder: step 5, image 1 of 1
      • Simply desolder the XT30 you desire to replace, then using either a wick or desoldering iron clean the area.
      • After this, resolder a new XT30 connector ensuring it is oriented correctly.
      Ask FixBot
Rhys Panopio
121 Reputation
1 Guide authored
4 Guide Comments
IMPORTANT 🚨 Do not use XT30 Connectors from rev or any other standard parts supplier. Most suppliers sell the “XT30U-M”. The connector that comes with the board is the XT30UPB-M”. This is an important distinction and the standard plug will not work in this board.
Tiger Li - Reply Share
@tiger_li , thank you for sharing the warning.
We are a wiki and if you'd like, you can make an edit directly to this guide to warn fixers who might be attempting this repair.
Kris Rodriguez - Reply Share
AndyMark sells the XT30UPB-M and XT30UPB-F now.
FTC Team #10298 Brain Stormz - Reply Share
Male XT30 Connector (Amass XT30UPB-M) and Female XT30 Connector (Amass XT30UPB-F) list a number of suppliers, I'm trying to figure out why this page only links to the first supplier in that list, rather than the full list?
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 136
All Time: 1,462
