Community-Contributed Guide
Introduction
Go to step 1 ↓Because of a design flaw in the REL T3/T5 series amplifier board, the power resistors boil the electrolytic capacitors. This guide shows the replacement process.
Replacement parts in this guide:
- C205 100uF 25V
- C204 100uF 25V
- C203 100uF 25V
- C213 4.7uF 50V
- C201 10uF 50V
- C212 10uF 50V
- R230 750, 560 in series (replaced with a 1k3 resistor)
- C208 220pF Ceramic disk
- R229 2k2red (normal 0.25W resistor)
Make sure the capacitors are suitable for high temperatures (105) and are long-life with low ESR, such as the Panasonic FR-A series. I used 50V instead of 25V, because of availability.
Tools
Place the subwoofer on it legs to protect the driver. Be careful not to touch the driver/speaker on the bottom when you handle the case.
Using the 3mm hex tool, remove only the outer rim of screws, starting from the bottom.
Make sure to support the plate amp by gripping the heat sink.
Remove the top screws. Be aware: the heavy transformer is located at the top. Removing the top screws will probably make the plate amp tilt out of the case.
Using the heatsink, carefully lift the plate amp out of the case. Again: it's heavier than you might expect!
The plate amp is still connected to the driver via faston connectors. I found it easiest to disconnect the driver connectors, but removing them from the amplifier side works equally well.
You've now removed the plate amp. Set it aside on the heatsink side. The height of the heatsink will make sure that the controls are not damaged.
Now is a good time to check the voltage rails for residual voltage. Everything after the rectifier bridge should be <45V, but always take appropriate precautions when it comes to mains powered devices.
Snip all tywraps, such that all cables can be manipulated freely.
Disconnect all connectors that tie to the transformer
Make sure that all leads can be manipulated freely.
Start loosening the screws on the back using the m3 hex tool
Don't remove them fully, yet though.
Turn the amp on it's back.
Remove the nuts from the screws that where loosened on the back.
Remove the philips screws using a #2.
Loosen the dampening rubber by running a Halberd Spudger underneath it.
The rubber is not adhered to the aluminium and is pretty tough, so a moderate amount of force is allowed.
You can now remove the transformer from the plate. Be careful not to damage the controls on the plate now that the assembly is a lot lighter.
Remove the screws to the thermistor.
Remove the screws to the transistors.
Store them in a separate baggy.
Gently lift up the PCB. The transistors might be held down by thermal paste, so use a spudger to release them.
Carefully remove silica pads, take note: they are very fragile!
Remove excessive black putty where needed.
Thoroughly clean back plate with Isopropyl Alcohol (IPA).
Clean silica pads as well and store them.
Mount back C201, C203, C204, C205, C213.
This restores the power rails to the op-amp.
The power resistors in my picture have already moved to the backplate.
Make sure all thermal components (transistors, power-resistors) have thermal paste applied.
Bolt down the transistors.
Make sure there are no shorts between the metal body of the transistors and the heatsink!
Hook the amp up to a Dim Bulb Tester. I used a halogen bulb, it works the same.
Make sure the light flashes when you turn the amp on, but then dims down.
Optionally use this cover on the mains pins, to reduce the risk of electrical shock.
Test the voltage on pin 4 and pin 7
Use ground from the speaker connector
Voltages should be around:
pin4: -14.5V
pin 7: 14.5V
Rebuild the last step: C212, C208, R229, R230. (this requires removing the board etc).
Power up, using the dim-bulb. The light should de dim, after the first flash after power up.
The relay should click.
Final test before disconnecting the dim-bulb: check that the DC offset on the speaker terminals is zero (or else yuor buying a new driver
You're now ready to hook the amp up directly to mains and listen to your music. Enjoy your upgrade!
Don't forget to reassemble first ;-)
Optional, but highly recommended for longevity
(Re)-Apply electronics glue to all protruding elements (wires, capacitors, ...)
I took a gamble and used Bison PolyMax, since I have no further use for electronics glue. It should be applicable, although impossible to remove. I'll worry about that later.
Make sure all tie wraps are in place, so everything is nice and tight.
