REL T3 Main Amplifier Capacitors Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
92
All Time:
175
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 hours
Difficulty: Very difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
Because of a design flaw in the REL T3/T5 series amplifier board, the power resistors boil the electrolytic capacitors. This guide shows the replacement process.
Replacement parts in this guide:
  • C205 100uF 25V
  • C204 100uF 25V
  • C203 100uF 25V
  • C213 4.7uF 50V
  • C201 10uF 50V
  • C212 10uF 50V
  • R230 750, 560 in series (replaced with a 1k3 resistor)
  • C208 220pF Ceramic disk
  • R229 2k2red (normal 0.25W resistor)
Make sure the capacitors are suitable for high temperatures (105) and are long-life with low ESR, such as the Panasonic FR-A series. I used 50V instead of 25V, because of availability.
Tools
    1. REL T3 Main Amplifier Capacitors Replacement, Remove screws: step 1, image 1 of 3 REL T3 Main Amplifier Capacitors Replacement, Remove screws: step 1, image 2 of 3 REL T3 Main Amplifier Capacitors Replacement, Remove screws: step 1, image 3 of 3
      • Place the subwoofer on it legs to protect the driver. Be careful not to touch the driver/speaker on the bottom when you handle the case.
      • Using the 3mm hex tool, remove only the outer rim of screws, starting from the bottom.
      • Make sure to support the plate amp by gripping the heat sink.
      • Remove the top screws. Be aware: the heavy transformer is located at the top. Removing the top screws will probably make the plate amp tilt out of the case.
      • Using the heatsink, carefully lift the plate amp out of the case. Again: it's heavier than you might expect!
      Ask FixBot
    2. REL T3 Main Amplifier Capacitors Replacement, Disconnect the driver: step 2, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Disconnect the driver: step 2, image 2 of 2
      • The plate amp is still connected to the driver via faston connectors. I found it easiest to disconnect the driver connectors, but removing them from the amplifier side works equally well.
      Ask FixBot
    3. REL T3 Main Amplifier Capacitors Replacement, Remove plate amp: step 3, image 1 of 1
      • You've now removed the plate amp. Set it aside on the heatsink side. The height of the heatsink will make sure that the controls are not damaged.
      • Now is a good time to check the voltage rails for residual voltage. Everything after the rectifier bridge should be <45V, but always take appropriate precautions when it comes to mains powered devices.
      Ask FixBot
    1. REL T3 Main Amplifier Capacitors Replacement, Snip all connecting trywraps: step 4, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Snip all connecting trywraps: step 4, image 2 of 2
      • Snip all tywraps, such that all cables can be manipulated freely.
      Ask FixBot
    2. REL T3 Main Amplifier Capacitors Replacement, Disconnect connectors: step 5, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Disconnect connectors: step 5, image 2 of 2
      • Disconnect all connectors that tie to the transformer
      • Make sure that all leads can be manipulated freely.
      Ask FixBot
    3. REL T3 Main Amplifier Capacitors Replacement, Loosen screws: step 6, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Loosen screws: step 6, image 2 of 2
      • Start loosening the screws on the back using the m3 hex tool
      • Don't remove them fully, yet though.
      Ask FixBot
    4. REL T3 Main Amplifier Capacitors Replacement, Remove screws: step 7, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Remove screws: step 7, image 2 of 2
      • Turn the amp on it's back.
      • Remove the nuts from the screws that where loosened on the back.
      • Remove the philips screws using a #2.
      Ask FixBot
    5. REL T3 Main Amplifier Capacitors Replacement, Loosen dampening rubber: step 8, image 1 of 1
      • Loosen the dampening rubber by running a Halberd Spudger underneath it.
      • The rubber is not adhered to the aluminium and is pretty tough, so a moderate amount of force is allowed.
      Ask FixBot
    6. REL T3 Main Amplifier Capacitors Replacement, Remove transformer: step 9, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Remove transformer: step 9, image 2 of 2
      • You can now remove the transformer from the plate. Be careful not to damage the controls on the plate now that the assembly is a lot lighter.
      Ask FixBot
    1. REL T3 Main Amplifier Capacitors Replacement, Remove connectors: step 10, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Remove connectors: step 10, image 2 of 2
      • Remove the connectors to the amp board.
      Ask FixBot
    2. REL T3 Main Amplifier Capacitors Replacement: step 11, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement: step 11, image 2 of 2
      • Discharge the capacitor e.g. using a replacement 1k3 power resistor.
      • Carefully bridge the resistor across the + and - legs of the recifier, but don't touch anything else.
      Ask FixBot
      • Verify that the voltage is near zero. 0.2V or so is fine.
      • The voltage starts at around 100V, so be careful.
      Ask FixBot
    3. REL T3 Main Amplifier Capacitors Replacement, Remove component screws: step 13, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Remove component screws: step 13, image 2 of 2
      • Remove the screws to the thermistor.
      • Remove the screws to the transistors.
      • Store them in a separate baggy.
      Ask FixBot
    4. REL T3 Main Amplifier Capacitors Replacement, Remove PCB screws: step 14, image 1 of 3 REL T3 Main Amplifier Capacitors Replacement, Remove PCB screws: step 14, image 2 of 3 REL T3 Main Amplifier Capacitors Replacement, Remove PCB screws: step 14, image 3 of 3
      • Remove screws for four corners.
      • Store them in or on their posts.
      Ask FixBot
    5. REL T3 Main Amplifier Capacitors Replacement, Lift the PCB: step 15, image 1 of 1
      • Gently lift up the PCB. The transistors might be held down by thermal paste, so use a spudger to release them.
      Ask FixBot
    1. REL T3 Main Amplifier Capacitors Replacement, Replace lower section: step 16, image 1 of 1
      • Mount back C201, C203, C204, C205, C213.
      • This restores the power rails to the op-amp.
      • The power resistors in my picture have already moved to the backplate.
      Ask FixBot
    2. REL T3 Main Amplifier Capacitors Replacement, Remount the amplifier: step 17, image 1 of 1
      • Make sure all thermal components (transistors, power-resistors) have thermal paste applied.
      • Bolt down the transistors.
      • Make sure there are no shorts between the metal body of the transistors and the heatsink!
      Ask FixBot
      • Hook the amp up to a Dim Bulb Tester. I used a halogen bulb, it works the same.
      • Make sure the light flashes when you turn the amp on, but then dims down.
      • Optionally use this cover on the mains pins, to reduce the risk of electrical shock.
      Ask FixBot
    3. REL T3 Main Amplifier Capacitors Replacement, Test OP-AMP: step 19, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Test OP-AMP: step 19, image 2 of 2
      • Test the voltage on pin 4 and pin 7
      • Use ground from the speaker connector
      • Voltages should be around:
      • pin4: -14.5V
      • pin 7: 14.5V
      Ask FixBot
    4. REL T3 Main Amplifier Capacitors Replacement, Rebuild amplifier board: step 20, image 1 of 1
      • Rebuild the last step: C212, C208, R229, R230. (this requires removing the board etc).
      • Power up, using the dim-bulb. The light should de dim, after the first flash after power up.
      • The relay should click.
      Ask FixBot
    5. REL T3 Main Amplifier Capacitors Replacement, Test output: step 21, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement, Test output: step 21, image 2 of 2
      • Final test before disconnecting the dim-bulb: check that the DC offset on the speaker terminals is zero (or else yuor buying a new driver
      • You're now ready to hook the amp up directly to mains and listen to your music. Enjoy your upgrade!
      • Don't forget to reassemble first ;-)
      Ask FixBot
    6. REL T3 Main Amplifier Capacitors Replacement: step 22, image 1 of 2 REL T3 Main Amplifier Capacitors Replacement: step 22, image 2 of 2
      • Optional, but highly recommended for longevity
      • (Re)-Apply electronics glue to all protruding elements (wires, capacitors, ...)
      • I took a gamble and used Bison PolyMax, since I have no further use for electronics glue. It should be applicable, although impossible to remove. I'll worry about that later.
      • Make sure all tie wraps are in place, so everything is nice and tight.
      Ask FixBot
Jasper van Zuijlen
1,165 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 92
All Time: 175
