RCA Voyager II RCT6773W22 Disassembly
    1. RCA Voyager II RCT6773W22 Disassembly, RCA Voyager II RCT6773W22 Disassembly: step 1, image 1 of 1
      • Have Workstation Prepped
      Ask FixBot
    2. RCA Voyager II RCT6773W22 Disassembly: step 2, image 1 of 1
      • remove the two screws on the top of the device with a PH000 screwdriver
      Ask FixBot
    3. RCA Voyager II RCT6773W22 Disassembly: step 3, image 1 of 1
      • Starting from the top, place pick or plastic tool between the power button and screen edge and push apart slightly.
      Ask FixBot
    4. RCA Voyager II RCT6773W22 Disassembly: step 4, image 1 of 1
      • Run pick across the top to the right and then down the right side and around the rest of the tablet.
      • There is a good amount of space between the bezel and the board. Be gentle, but the risk of breaking components is low.
      Ask FixBot
    5. RCA Voyager II RCT6773W22 Disassembly: step 5, image 1 of 2 RCA Voyager II RCT6773W22 Disassembly: step 5, image 2 of 2
      • lift section out of the black casing from the bottom, lift and remove by pulling away from tablet.
      Ask FixBot
    6. RCA Voyager II RCT6773W22 Disassembly: step 6, image 1 of 1
      • Battery connection (on older models, may be soldered to board)
      • Front Camera
      • Digitizer
      • LCD
      • Speaker
      Ask FixBot
    7. RCA Voyager II RCT6773W22 Disassembly: step 7, image 1 of 1
      • Remove battery Connection First
      • Do not use any metal tools while the battery is plugged in. It may cause a short.
      Ask FixBot
    8. RCA Voyager II RCT6773W22 Disassembly: step 8, image 1 of 1
      • unplug the speaker
      Ask FixBot
    9. RCA Voyager II RCT6773W22 Disassembly: step 9, image 1 of 3 RCA Voyager II RCT6773W22 Disassembly: step 9, image 2 of 3 RCA Voyager II RCT6773W22 Disassembly: step 9, image 3 of 3
      • Lift the black cover over all three flex cables (Camera, LCD, Digitizer) with a plastic tool.
      • The covers are incredibly fragile, and easy to break
      • gently disconnect all three cables with your fingers by pulling slightly
      Ask FixBot
    10. RCA Voyager II RCT6773W22 Disassembly: step 10, image 1 of 1
      • remove the three screws securing the board with your PH000 Screwdriver
      Ask FixBot
    11. RCA Voyager II RCT6773W22 Disassembly: step 11, image 1 of 2 RCA Voyager II RCT6773W22 Disassembly: step 11, image 2 of 2
      • lift the board out gently
      • Do not tug the board out too hard, the antenna cable on the left is soldered in!
      • Fold board over the left side of the tablet and gently remove tape securing antenna to the case. Use a small amount of heat if necessary.
      Ask FixBot
    12. RCA Voyager II RCT6773W22 Disassembly: step 12, image 1 of 2 RCA Voyager II RCT6773W22 Disassembly: step 12, image 2 of 2
      • remove tape from top and bottom of the battery.
      • with a plastic piece, lift battery from adhesive securing it in place.
      • do not use a metal or sharp tool to remove the battery, tearing or puncturing it may cause it to explode or heat rapidly, and may damage your device.
      • The battery is secured directly to the back of the LCD. Exercise caution while removing the battery not to damage the LCD.
      • The battery is soft and somewhat malleable - it can bend slightly without damage.
      Ask FixBot
    13. RCA Voyager II RCT6773W22 Disassembly: step 13, image 1 of 2 RCA Voyager II RCT6773W22 Disassembly: step 13, image 2 of 2
      • Place picks between the lcd and the plastic clips holding it in place.
      • The pick placement to the top left side (near the power button) is smaller and on a corner. I recommend inserting this pick last.
      Ask FixBot
    14. RCA Voyager II RCT6773W22 Disassembly: step 14, image 1 of 1
      • Gently push top right pick down to lift LCD from the clip. Run across the top and right side to further lift LCD.
      • Use picks as needed to separate LCD in other areas.
      Ask FixBot
    15. RCA Voyager II RCT6773W22 Disassembly: step 15, image 1 of 1
      • Once separated and loose, remove picks so you do not damage the LCD while removing it.
      • To remove, lift top of LCD and pull out of case away from the speaker, which is fixed to the digitizer frame.
      Ask FixBot
    16. RCA Voyager II RCT6773W22 Disassembly: step 16, image 1 of 2 RCA Voyager II RCT6773W22 Disassembly: step 16, image 2 of 2
      • to remove Digitizer/Glass from the frame and speaker, slide a pick under a corner between the glass and frame to loosen adhesive
      • If you're having issues loosening the adhesive, use a heat gun around the edges, then try again.
      Ask FixBot
    17. RCA Voyager II RCT6773W22 Disassembly: step 17, image 1 of 1
      • You have completely dismantled the RCA Voyager II
      Ask FixBot
35 other people completed this guide.
Chris
2,025 Reputation
1 Guide authored
31 Guide Comments
what is that flat part that has the little copper bar in the middle. What do you call that?
TheUnchanted Sword - Reply Share
The LCD has a piece of copper tape on it, is that what you mean?
Sam Goldheart - Reply Share
Nice Guide. Very Simple and Easy to follow!
Aerial L - Reply Share
Bonne site merci pour tous je suis très heureux content que entrer dans ce site
diego jamal - Reply Share
Anyone know which company made this very fragile digitizer for RCA Voyager?
Spock Chen - Reply Share
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 91
All Time: 23,051
