RCA ViSYS 25424RE1 Keypad Replacement
  1. RCA ViSYS 25424RE1 Keypad Replacement, Base: step 1, image 1 of 3 RCA ViSYS 25424RE1 Keypad Replacement, Base: step 1, image 2 of 3 RCA ViSYS 25424RE1 Keypad Replacement, Base: step 1, image 3 of 3
    • Remove the eight 11mm screws found on the bottom side of the base with a Phillips #00 screwdriver.
    Ask FixBot
  2. RCA ViSYS 25424RE1 Keypad Replacement: step 2, image 1 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 2, image 2 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to separate the back and front pieces.
    • Gently remove the back cover, because the wires are connected to each piece.
    Ask FixBot
  3. RCA ViSYS 25424RE1 Keypad Replacement: step 3, image 1 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 3, image 2 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 3, image 3 of 3
    • Unclip the wires that connect the front piece to the circuit board on the back piece.
    Ask FixBot
  4. RCA ViSYS 25424RE1 Keypad Replacement, Keypad: step 4, image 1 of 2 RCA ViSYS 25424RE1 Keypad Replacement, Keypad: step 4, image 2 of 2
    • Remove the nine 11mm screws from the board using a Phillips #00 screwdriver, in order to expose the keyboard pressure sensors.
    Ask FixBot
  5. RCA ViSYS 25424RE1 Keypad Replacement: step 5, image 1 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 5, image 2 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Lift the rubber keypad.
    • Use a pair of tweezers to lift the number pad from both ends at the same time.
    Ask FixBot
Munija Ramin
143 Reputation
1 Guide authored
Penn State, Team 1-17, Kaschak Winter 2015 Member of Penn State, Team 1-17, Kaschak Winter 2015
PSU-KASCHAK-W15S1G17
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 549
