RCA ViSYS 25424RE1 Base Disassembly
  1. RCA ViSYS 25424RE1 Base Disassembly, Base: step 1, image 1 of 3 RCA ViSYS 25424RE1 Base Disassembly, Base: step 1, image 2 of 3 RCA ViSYS 25424RE1 Base Disassembly, Base: step 1, image 3 of 3
    • Remove the eight 11mm screws found on the bottom side of the base with a Phillips #00 screwdriver.
    Ask FixBot
  2. RCA ViSYS 25424RE1 Base Disassembly: step 2, image 1 of 3 RCA ViSYS 25424RE1 Base Disassembly: step 2, image 2 of 3 RCA ViSYS 25424RE1 Base Disassembly: step 2, image 3 of 3
    • Use a plastic opening tool to separate the back and front pieces.
    • Gently remove the back cover, because the wires are connected to each piece.
    Ask FixBot
  3. RCA ViSYS 25424RE1 Base Disassembly: step 3, image 1 of 3 RCA ViSYS 25424RE1 Base Disassembly: step 3, image 2 of 3 RCA ViSYS 25424RE1 Base Disassembly: step 3, image 3 of 3
    • Unclip the wires that connect the front piece to the circuit board on the back piece.
    Ask FixBot
Mit Patel
255 Reputation
2 Guides authored
Penn State, Team 1-17, Kaschak Winter 2015 Member of Penn State, Team 1-17, Kaschak Winter 2015
PSU-KASCHAK-W15S1G17
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 11
All Time: 749
