RCA RP3715A Motherboard Replacement
  1. RCA RP3715A Motherboard Replacement, Getting inside the device.: step 1, image 1 of 1
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
    Ask FixBot
  2. RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: step 2, image 1 of 3 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: step 2, image 2 of 3 RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: step 2, image 3 of 3
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
    Ask FixBot
  3. RCA RP3715A Motherboard Replacement: step 3, image 1 of 2 RCA RP3715A Motherboard Replacement: step 3, image 2 of 2
    • Using flathead screwdriver undo the release tabs.
    Ask FixBot
  4. RCA RP3715A Motherboard Replacement: step 4, image 1 of 3 RCA RP3715A Motherboard Replacement: step 4, image 2 of 3 RCA RP3715A Motherboard Replacement: step 4, image 3 of 3
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
    Ask FixBot
  5. RCA RP3715A Motherboard Replacement: step 5, image 1 of 2 RCA RP3715A Motherboard Replacement: step 5, image 2 of 2
    • Pry open both tabs to remove the topside of the clock.
    Ask FixBot
  6. RCA RP3715A Motherboard Replacement, Speaker Replacement: step 6, image 1 of 1
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
    Ask FixBot
  7. RCA RP3715A Motherboard Replacement, Detaching the front panel: step 7, image 1 of 1
    • Remove the two 10 mm Phillip's #1 screws.
    Ask FixBot
  8. RCA RP3715A Motherboard Replacement: step 8, image 1 of 1
    • Remove the gray panel from the frame.
    Ask FixBot
  9. RCA RP3715A Motherboard Replacement, Unlatch release tabs: step 9, image 1 of 3 RCA RP3715A Motherboard Replacement, Unlatch release tabs: step 9, image 2 of 3 RCA RP3715A Motherboard Replacement, Unlatch release tabs: step 9, image 3 of 3
    • The two latches located in the picture will help take off the display.
    • Remove the display.
    Ask FixBot
  10. RCA RP3715A Motherboard Replacement, Motherboard: step 10, image 1 of 2 RCA RP3715A Motherboard Replacement, Motherboard: step 10, image 2 of 2
    • asd
    Ask FixBot
  11. RCA RP3715A Motherboard Replacement, Removing the top part of motherboard: step 11, image 1 of 1
    • Remove the top 5 10mm Phillips #1 screws holding the top part of the motherboard
    Ask FixBot
  12. RCA RP3715A Motherboard Replacement, Removing the side part of motherboard: step 12, image 1 of 1
    • Remove the 5 10mm Phillip's #1 screws that holding side part of the motherboard
    Ask FixBot
  13. RCA RP3715A Motherboard Replacement: step 13, image 1 of 1
    • Remove the transformer by pulling back the release tab shown.
    Ask FixBot
  14. RCA RP3715A Motherboard Replacement: step 14, image 1 of 1
    • Pull the battery terminal through the whole shown.
    Ask FixBot
  15. RCA RP3715A Motherboard Replacement, Lift the digital screen: step 15, image 1 of 1
    • First release the latch highlighted in the picture. Then grab the screen by the bottom and lift it up.
    Ask FixBot
  16. RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: step 16, image 1 of 3 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: step 16, image 2 of 3 RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: step 16, image 3 of 3
    • Remove the motherboard from the frame using the illustration shown.
    Ask FixBot
Alexander Trowell
222 Reputation
2 Guides authored
USF Tampa, Team 10-5, Brown Fall 2014 Member of USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 849
