RCA RP3715A Display Replacement
    1. RCA RP3715A Display Replacement, Reaching the battery terminal.: step 1, image 1 of 2 RCA RP3715A Display Replacement, Reaching the battery terminal.: step 1, image 2 of 2
      • Push down on the clip to release pressure. The pull off the plastic cover.
      Ask FixBot
    2. RCA RP3715A Display Replacement, Replacing the battery: step 2, image 1 of 1
      • Remove the 9-volt battery from the battery terminal.
      Ask FixBot
    1. RCA RP3715A Display Replacement, Getting inside the device.: step 3, image 1 of 1
      • Take out the six screws located on the back of the device.
      • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
      • Three screws are located on the back panel. One is located inside the battery carriage.
      • Two screws are located on the on the back panel on the bottom left and right side.
      Ask FixBot
    2. RCA RP3715A Display Replacement, Relieve extension cord tension.: step 4, image 1 of 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: step 4, image 2 of 3 RCA RP3715A Display Replacement, Relieve extension cord tension.: step 4, image 3 of 3
      • Remove the 10 mm Phillip's #1 screw.
      • Then remove the metal reinforcement.
      Ask FixBot
    3. RCA RP3715A Display Replacement: step 5, image 1 of 2 RCA RP3715A Display Replacement: step 5, image 2 of 2
      • Using flathead screwdriver undo the release tabs.
      Ask FixBot
    4. RCA RP3715A Display Replacement: step 6, image 1 of 3 RCA RP3715A Display Replacement: step 6, image 2 of 3 RCA RP3715A Display Replacement: step 6, image 3 of 3
      • Pry the release tabs with a spudger.
      • Start with back of the device on the topside.
      Ask FixBot
    5. RCA RP3715A Display Replacement: step 7, image 1 of 2 RCA RP3715A Display Replacement: step 7, image 2 of 2
      • Pry open both tabs to remove the topside of the clock.
      Ask FixBot
    6. RCA RP3715A Display Replacement, Speaker Replacement: step 8, image 1 of 1
      • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
      Ask FixBot
    1. RCA RP3715A Display Replacement, Detaching the front panel: step 9, image 1 of 1
      • Remove the two 10 mm Phillip's #1 screws.
      Ask FixBot
    2. RCA RP3715A Display Replacement: step 10, image 1 of 1
      • Remove the gray panel from the frame.
      Ask FixBot
    3. RCA RP3715A Display Replacement, Unlatch release tabs: step 11, image 1 of 3 RCA RP3715A Display Replacement, Unlatch release tabs: step 11, image 2 of 3 RCA RP3715A Display Replacement, Unlatch release tabs: step 11, image 3 of 3
      • The two latches located in the picture will help take off the display.
      • Remove the display.
      Ask FixBot
Myles Waiters
370 Reputation
3 Guides authored
USF Tampa, Team 10-5, Brown Fall 2014 Member of USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 26
All Time: 686
