RCA RCT6773W22 Battery Replacement
    1. RCA RCT6773W22 Battery Replacement, Battery: step 1, image 1 of 2 RCA RCT6773W22 Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
      Ask FixBot
    2. RCA RCT6773W22 Battery Replacement: step 2, image 1 of 3 RCA RCT6773W22 Battery Replacement: step 2, image 2 of 3 RCA RCT6773W22 Battery Replacement: step 2, image 3 of 3
      • Place the plastic opening tool between the case and the screen.
      • Slide the tool clockwise around the case until all the clips are removed.
      • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
      Ask FixBot
    3. RCA RCT6773W22 Battery Replacement: step 3, image 1 of 3 RCA RCT6773W22 Battery Replacement: step 3, image 2 of 3 RCA RCT6773W22 Battery Replacement: step 3, image 3 of 3
      • Desolder the two wires that connect the battery to the motherboard.
      • Learn more about soldering with this soldering technique guide.
      • Using the blue plastic opening tool, lift the battery away from the device.
      Ask FixBot
2 other people completed this guide.
Kelsea Weber
21,491 Reputation
32 Guides authored
1 Guide Comment
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
Cathy Hajo - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 4,468
