Up to 20% off select tools
RCA RCT6378W2 Screen Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
80
All Time:
3,122
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
If the screen of the device becomes cracked or stops registering touch commands, use the following guide to replace the screen.
    1. RCA RCT6378W2 Screen Replacement, Screen: step 1, image 1 of 1
      • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
      Ask FixBot
    2. RCA RCT6378W2 Screen Replacement: step 2, image 1 of 2 RCA RCT6378W2 Screen Replacement: step 2, image 2 of 2
      • Remove back cover with plastic opening tool, exposing the battery and motherboard.
      Ask FixBot
    3. RCA RCT6378W2 Screen Replacement: step 3, image 1 of 2 RCA RCT6378W2 Screen Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, remove the black tape connecting the screen to the motherboard.
      Ask FixBot
    4. RCA RCT6378W2 Screen Replacement: step 4, image 1 of 2 RCA RCT6378W2 Screen Replacement: step 4, image 2 of 2
      • Pull up the switch to remove the input connector.
      Ask FixBot
    5. RCA RCT6378W2 Screen Replacement: step 5, image 1 of 1
      • Heat the iOpener in the microwave, following the instructions provided with the tool. Lay the heated iOpener on the front screen for two minutes to soften the connection of the screen to the tablet.
      Ask FixBot
    6. RCA RCT6378W2 Screen Replacement: step 6, image 1 of 2 RCA RCT6378W2 Screen Replacement: step 6, image 2 of 2
      • Use the suction cup and plastic opening tool to pry the front screen from the tablet.
      Ask FixBot
3 other people completed this guide.
Author
with
Matthew Wills
468 Reputation
4 Guides authored
Clemson, Team 14-4, Shirley Spring 2015 Member of Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Members
120 Guides authored
1 Guide Comment
How to fix rca 7
Jagdeep Thandi - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 80
All Time: 3,122
