RCA RCT6303W87 Battery Replacement
    1. RCA RCT6303W87 Battery Replacement, Battery: step 1, image 1 of 3 RCA RCT6303W87 Battery Replacement, Battery: step 1, image 2 of 3 RCA RCT6303W87 Battery Replacement, Battery: step 1, image 3 of 3
      • Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
      Ask FixBot
    2. RCA RCT6303W87 Battery Replacement: step 2, image 1 of 1
      • Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
      Ask FixBot
    3. RCA RCT6303W87 Battery Replacement: step 3, image 1 of 3 RCA RCT6303W87 Battery Replacement: step 3, image 2 of 3 RCA RCT6303W87 Battery Replacement: step 3, image 3 of 3
      • Remove cover completely.
      Ask FixBot
    4. RCA RCT6303W87 Battery Replacement: step 4, image 1 of 3 RCA RCT6303W87 Battery Replacement: step 4, image 2 of 3 RCA RCT6303W87 Battery Replacement: step 4, image 3 of 3
      • Disconnect battery cable from the motherboard.
      Ask FixBot
    5. RCA RCT6303W87 Battery Replacement: step 5, image 1 of 3 RCA RCT6303W87 Battery Replacement: step 5, image 2 of 3 RCA RCT6303W87 Battery Replacement: step 5, image 3 of 3
      • Pull the thin black keyboard connector off and set it aside.
      Ask FixBot
    6. RCA RCT6303W87 Battery Replacement: step 6, image 1 of 3 RCA RCT6303W87 Battery Replacement: step 6, image 2 of 3 RCA RCT6303W87 Battery Replacement: step 6, image 3 of 3
      • Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
      Ask FixBot
    7. RCA RCT6303W87 Battery Replacement: step 7, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Use nylon spudger tool or plastic card to separate battery from the case.
      Ask FixBot
    8. RCA RCT6303W87 Battery Replacement: step 8, image 1 of 3 RCA RCT6303W87 Battery Replacement: step 8, image 2 of 3 RCA RCT6303W87 Battery Replacement: step 8, image 3 of 3
      • Carefully peel off the battery.
      Ask FixBot
16 other people completed this guide.
Akitaka Hashimoto
540 Reputation
2 Guides authored
IUPUI, Team S3-G2, Harley Spring 2018 Member of IUPUI, Team S3-G2, Harley Spring 2018
IUPUI-HARLEY-S18S3G2
3 Members
24 Guides authored
5 Guide Comments
Thank you very much for the instructions. I was totally in the blind about what to unplug or not.
Diamante Swift - Reply Share
“Remove nine 4.8mm screws “ but you only show pictures of 7 screws.
George Phillips - Reply Share
2 are hidden under the black hinge. you would have to remove the 3 tiny screw in order to get access to the hidden 2 screws.
Ed Barry - Reply Share
Thanks for the instructions. I don’t know if mine is newer or older but the bus cable turns 90 degrees and goes under the keyboard cable so step 6 really wasn’t necessary. A plastic putty knife slid under old battery loosening the adhesive so you can slide it out from under the bus cable.
Steve Bunce - Reply Share
Super helpful- worked great!
denise turley - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 35
All Time: 6,983
