RCA RCT6203W46 Rear Camera Replacement
    1. RCA RCT6203W46 Rear Camera Replacement, Front and Rear Camera: step 1, image 1 of 2 RCA RCT6203W46 Rear Camera Replacement, Front and Rear Camera: step 1, image 2 of 2
      • Make sure the device is off to reduce the chance of an electrical shock. To turn off the device, press and hold the power button.
      • Use a Phillips #00 Screwdriver to unscrew the 4mm (5/32 in.) screws from the back cover of the tablet.
      Ask FixBot
    2. RCA RCT6203W46 Rear Camera Replacement: step 2, image 1 of 2 RCA RCT6203W46 Rear Camera Replacement: step 2, image 2 of 2
      • Use a spudger to pry the back cover. Start from one edge of the back cover and slide across until the cover is lifted from the tablet body. Repeat for all edges.
      Ask FixBot
    3. RCA RCT6203W46 Rear Camera Replacement: step 3, image 1 of 1
      • Open the tablet cover carefully and slowly lengthwise.
      • The keyboard wire ribbon and rear speaker wire should be intact and connected with the back cover.
      • Opening the tablet abruptly may tear or damage cover attachments.
      Ask FixBot
    4. RCA RCT6203W46 Rear Camera Replacement: step 4, image 1 of 1
      • Use a spudger to flip up the flap of the ZIF connector that holds the keyboard wire ribbon.
      • Remove the wire ribbon from clamp.
      Ask FixBot
    5. RCA RCT6203W46 Rear Camera Replacement: step 5, image 1 of 2 RCA RCT6203W46 Rear Camera Replacement: step 5, image 2 of 2
      • Attached to the motherboard you will see two orange ribbons connected to black tabs.
      • Using both hands, place your thumbs gently on the black tab attached to the top and gently lift it.
      • Proceed to slide the orange colored ribbon out from underneath until it is detached from the black tab.
      Ask FixBot
    6. RCA RCT6203W46 Rear Camera Replacement: step 6, image 1 of 1
      • Use a spudger to pry and slide underneath the battery to unstick it from the LCD metal plate. It may take a good amount of force to remove.
      • Try to decrease battery deformation by using a spudger rather than prying with your hands.
      • Do not let battery fall back on adhesive, it will stick back onto the LCD metal plate.
      • Be careful to not puncture the battery. The battery may ignite or explode.
      Ask FixBot
    7. RCA RCT6203W46 Rear Camera Replacement: step 7, image 1 of 2 RCA RCT6203W46 Rear Camera Replacement: step 7, image 2 of 2
      • Gently remove the grey tape that's covering the grey colored wire until it is completely peeled off.
      • Peel off the black piece of tape to remove the antenna.
      Ask FixBot
    8. RCA RCT6203W46 Rear Camera Replacement: step 8, image 1 of 1
      • Unscrew three of the 4 mm screws on the motherboard using a Phillips #00 screwdriver.
      • After removing the screws, detach the motherboard from the rest of the tablet. Use a spudger to gently remove it, if necessary.
      Ask FixBot
    9. RCA RCT6203W46 Rear Camera Replacement: step 9, image 1 of 1
      • Locate the rear camera and use a prying tool to gently lift the rear camera off of the motherboard.
      Ask FixBot
    10. RCA RCT6203W46 Rear Camera Replacement: step 10, image 1 of 1
      • Detach the camera ribbon wire by lifting the tab and pulling the wire. This will leave you with the camera assembly.
      Ask FixBot
Grace Chung
212 Reputation
1 Guide authored
UC Davis, Team 1-2, Oliver Fall 2016 Member of UC Davis, Team 1-2, Oliver Fall 2016
UCD-OLIVER-F16S1G2
5 Members
48 Guides authored
1 Guide Comment
Where can I get the main board from RCT6203W46
top - Reply Share
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 26
All Time: 640
