Introduction
This guide will show how to replace the LCD screen on the RCA RCR8622.
Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
Tool used on this step:Tweezers$4.99
Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
Remove the two 11mm screws from the motherboard with the Phillip's #1 screwdriver.
Squeeze the 2 metal prongs on the interior of the motherboard inward until a clicking noise is heard.
