RCA Pro10 Edition Speaker Replacement
    1. RCA Pro10 Edition Speaker Replacement, Speaker: step 1, image 1 of 2 RCA Pro10 Edition Speaker Replacement, Speaker: step 1, image 2 of 2
      • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
      • Use the prying tool to separate the front and back casing, working your way around the perimeter.
      • Utilize a card tool or a pick to assist in keeping the case separated.
      • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
      Ask FixBot
    2. RCA Pro10 Edition Speaker Replacement: step 2, image 1 of 1
      • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
      • Remove the yellow tape securing the speaker to the back casing.
      Ask FixBot
    3. RCA Pro10 Edition Speaker Replacement: step 3, image 1 of 2 RCA Pro10 Edition Speaker Replacement: step 3, image 2 of 2
      • Use the separating tool to pry the speaker from its surface.
      • Use caution when removing the speaker, you may damage the screen.
      • Cut or desolder the wires to replace or repair the speaker.
      Ask FixBot
Dayne Russell
404 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 25
All Time: 994
