Up to 20% off select tools
RCA Pro10 Edition Camera Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
91
All Time:
881
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. RCA Pro10 Edition Camera Replacement, Speaker: step 1, image 1 of 2 RCA Pro10 Edition Camera Replacement, Speaker: step 1, image 2 of 2
      • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
      • Use the prying tool to separate the front and back casing, working your way around the perimeter.
      • Utilize a card tool or a pick to assist in keeping the case separated.
      • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
      Ask FixBot
    2. RCA Pro10 Edition Camera Replacement: step 2, image 1 of 1
      • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
      • Remove the yellow tape securing the speaker to the back casing.
      Ask FixBot
    3. RCA Pro10 Edition Camera Replacement: step 3, image 1 of 2 RCA Pro10 Edition Camera Replacement: step 3, image 2 of 2
      • Use the separating tool to pry the speaker from its surface.
      • Use caution when removing the speaker, you may damage the screen.
      • Cut or desolder the wires to replace or repair the speaker.
      Ask FixBot
    1. RCA Pro10 Edition Camera Replacement, Camera: step 4, image 1 of 3 RCA Pro10 Edition Camera Replacement, Camera: step 4, image 2 of 3 RCA Pro10 Edition Camera Replacement, Camera: step 4, image 3 of 3
      • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
      • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
      Ask FixBot
    2. RCA Pro10 Edition Camera Replacement: step 5, image 1 of 2 RCA Pro10 Edition Camera Replacement: step 5, image 2 of 2
      • Lift the locking tab that is securing the camera ribbon cable.
      • Slide the ribbon cable out from the connector and remove from casing.
      Ask FixBot
Author
with
Dayne Russell
404 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 91
All Time: 881
