Up to 20% off select tools
RCA Pro10 Edition Battery Replacement
Views: 17K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
94
All Time:
16,779
Comments: 0
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Outline what you are going to teach someone how to do.
    1. RCA Pro10 Edition Battery Replacement, Speaker: step 1, image 1 of 2 RCA Pro10 Edition Battery Replacement, Speaker: step 1, image 2 of 2
      • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
      • Use the prying tool to separate the front and back casing, working your way around the perimeter.
      • Utilize a card tool or a pick to assist in keeping the case separated.
      • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
      Ask FixBot
    2. RCA Pro10 Edition Battery Replacement: step 2, image 1 of 1
      • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
      • Remove the yellow tape securing the speaker to the back casing.
      Ask FixBot
    3. RCA Pro10 Edition Battery Replacement: step 3, image 1 of 2 RCA Pro10 Edition Battery Replacement: step 3, image 2 of 2
      • Use the separating tool to pry the speaker from its surface.
      • Use caution when removing the speaker, you may damage the screen.
      • Cut or desolder the wires to replace or repair the speaker.
      Ask FixBot
    1. RCA Pro10 Edition Battery Replacement, Battery: step 4, image 1 of 2 RCA Pro10 Edition Battery Replacement, Battery: step 4, image 2 of 2
      • Peel off the black tape on the battery and main-board.
      • Peel off the black tape securing the screen ribbon cable to the back of the screen.
      • Use caution to avoid damaging either ribbon cable.
      Ask FixBot
    2. RCA Pro10 Edition Battery Replacement: step 5, image 1 of 2 RCA Pro10 Edition Battery Replacement: step 5, image 2 of 2
      • Slide out the ribbon cable lock that is securing the screen ribbon cable.
      • Move the ribbon cable out of the way using tape if necessary.
      Ask FixBot
    3. RCA Pro10 Edition Battery Replacement: step 6, image 1 of 2 RCA Pro10 Edition Battery Replacement: step 6, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Remove the yellow tape securing the battery to the screen.
      • Use a plastic card or pick to separate the battery from the screen.
      • Do not bend or puncture battery, battery is difficult to separate from screen.
      • Cut or desolder the wires on the battery to remove or replace it.
      Ask FixBot
10 other people completed this guide.
Author
with
Dayne Russell
404 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 94
All Time: 16,779
