RCA Maven Pro 11 Reset Button Replacement
    1. RCA Maven Pro 11 Reset Button Replacement, Cover: step 1, image 1 of 2 RCA Maven Pro 11 Reset Button Replacement, Cover: step 1, image 2 of 2
      • Remove all the 8 mm Phillips head screws on the side and back of the device.
      Ask FixBot
    2. RCA Maven Pro 11 Reset Button Replacement: step 2, image 1 of 2 RCA Maven Pro 11 Reset Button Replacement: step 2, image 2 of 2
      • Pry off the cover by sticking a wedge in between the screen and the cover.
      • Be careful with the plastic because it can easily break.
      • Once the cover is partly removed, use your hands to take off the rest of the cover.
      Ask FixBot
    1. RCA Maven Pro 11 Reset Button Replacement, Reset Button: step 3, image 1 of 1
      • Locate the power button on the cover.
      Ask FixBot
    2. RCA Maven Pro 11 Reset Button Replacement: step 4, image 1 of 2 RCA Maven Pro 11 Reset Button Replacement: step 4, image 2 of 2
      • Carefully pull up on the power button. There are two pins holding it in.
      • Remove the power button.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 598
