RCA Maven Pro 11 Motherboard Replacement
    1. RCA Maven Pro 11 Motherboard Replacement, Motherboard: step 1, image 1 of 3 RCA Maven Pro 11 Motherboard Replacement, Motherboard: step 1, image 2 of 3 RCA Maven Pro 11 Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Use a Phillip's head screwdriver to unscrew the screws that secure the back cover in place. There are 6 screws in total (4 black, 2 silver).
      Ask FixBot
    2. RCA Maven Pro 11 Motherboard Replacement: step 2, image 1 of 3 RCA Maven Pro 11 Motherboard Replacement: step 2, image 2 of 3 RCA Maven Pro 11 Motherboard Replacement: step 2, image 3 of 3
      • Using a prying tool to pry off the back cover of the tablet. To do this, insert the prying tool between the screen and the side of the tablet.
      • Once the prying tool is inserted, run it along the edge of the tablet until the back cover pops off.
      Ask FixBot
    3. RCA Maven Pro 11 Motherboard Replacement: step 3, image 1 of 1
      • Use a Phillips head screwdriver to unscrew the 4 black screws that secure the motherboard to the device.
      Ask FixBot
    4. RCA Maven Pro 11 Motherboard Replacement: step 4, image 1 of 3 RCA Maven Pro 11 Motherboard Replacement: step 4, image 2 of 3 RCA Maven Pro 11 Motherboard Replacement: step 4, image 3 of 3
      • On the long edge of the motherboard, remove all of the ribbon and bundled cables.
      • The ZIF connections are removed by lifting up the small black tab on the connector and simply pulling out the ribbon cable(s).
      • Insert a spudger or plastic opening tool under the lip of the white bundled cable connector(s), and push the connector(s) free.
      Ask FixBot
    5. RCA Maven Pro 11 Motherboard Replacement: step 5, image 1 of 3 RCA Maven Pro 11 Motherboard Replacement: step 5, image 2 of 3 RCA Maven Pro 11 Motherboard Replacement: step 5, image 3 of 3
      • On the short edge of the motherboard, remove the yellow wire. To do this, lift up the clamp and pull out the wire.
      Ask FixBot
    6. RCA Maven Pro 11 Motherboard Replacement: step 6, image 1 of 1
      • Lift motherboard off the back of the tablet.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 55
All Time: 967
