RCA Maven Pro 11 Battery Replacement
    1. RCA Maven Pro 11 Battery Replacement, Cover: step 1, image 1 of 2 RCA Maven Pro 11 Battery Replacement, Cover: step 1, image 2 of 2
      • Remove all the 8 mm Phillips head screws on the side and back of the device.
      Ask FixBot
    2. RCA Maven Pro 11 Battery Replacement: step 2, image 1 of 2 RCA Maven Pro 11 Battery Replacement: step 2, image 2 of 2
      • Pry off the cover by sticking a wedge in between the screen and the cover.
      • Be careful with the plastic because it can easily break.
      • Once the cover is partly removed, use your hands to take off the rest of the cover.
      Ask FixBot
    1. RCA Maven Pro 11 Battery Replacement, Battery: step 3, image 1 of 2 RCA Maven Pro 11 Battery Replacement, Battery: step 3, image 2 of 2
      • Pull out the pins circled in the picture.
      • These pins can be removed by hand. Just pull on them individually.
      Ask FixBot
    2. RCA Maven Pro 11 Battery Replacement: step 4, image 1 of 1
      • Use the opening tools to peel the battery off of the panel.
      • The glue is located in the corners.
      • Do not bend or puncture the battery.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
My husband installed my new battery in my ex's haven pro tablet and when we turned it on it said battery charger 65%. I then turned it back off to co time charging to 100% it when I checked in a few hours, the battery level dropped to 20% and I cannot get it to recharge. It is now completely dead and will not take a charge what should I do?
Carol tyciak - Reply Share
My husband installed a new battery into my RCA Maven Pro tablet and when we turned it on, it showed 65% battery life. I then turned it off to continue to charge to 100%. When I checked it in about 4 hours, it was down to 20% and now it is depleted completely and I can't get it to recharge. What should I do now?
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 2,007
