RCA Lyra x2400 Screen Replacement
    1. RCA Lyra x2400 Screen Replacement, Battery: step 1, image 1 of 3 RCA Lyra x2400 Screen Replacement, Battery: step 1, image 2 of 3 RCA Lyra x2400 Screen Replacement, Battery: step 1, image 3 of 3
      • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
      • Remove the battery plate.
      • Place your finger at the bottom of the battery.
      • Lift up on the battery until it pops out from the LYRA X2400.
      Ask FixBot
    1. RCA Lyra x2400 Screen Replacement, Screen: step 2, image 1 of 2 RCA Lyra x2400 Screen Replacement, Screen: step 2, image 2 of 2
      • Remove the two Phillips screws from the silver cover at the top of the Lyra.
      • Slowly wiggle the silver cover while pulling it away from the device.
      Ask FixBot
    2. RCA Lyra x2400 Screen Replacement: step 3, image 1 of 2 RCA Lyra x2400 Screen Replacement: step 3, image 2 of 2
      • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
      • Pull the silver case from the bottom of the device.
      Ask FixBot
    3. RCA Lyra x2400 Screen Replacement: step 4, image 1 of 3 RCA Lyra x2400 Screen Replacement: step 4, image 2 of 3 RCA Lyra x2400 Screen Replacement: step 4, image 3 of 3
      • Carefully pry up the screen with a plastic opening tool.
      • Disconnect the screen's ribbon cable from the circuit board.
      • Remove the screen.
      Ask FixBot
Emmett
1 Reputation
1 Guide authored
Cal Poly, Team 17-3, Regan Spring 2013 Member of Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 38
All Time: 673
