RCA Lyra X2400 flash card reader replacement
  1. RCA Lyra X2400 flash card reader replacement, Battery: step 1, image 1 of 3 RCA Lyra X2400 flash card reader replacement, Battery: step 1, image 2 of 3 RCA Lyra X2400 flash card reader replacement, Battery: step 1, image 3 of 3
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
    Ask FixBot
  2. RCA Lyra X2400 flash card reader replacement, Screen: step 2, image 1 of 2 RCA Lyra X2400 flash card reader replacement, Screen: step 2, image 2 of 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
    Ask FixBot
  3. RCA Lyra X2400 flash card reader replacement: step 3, image 1 of 2 RCA Lyra X2400 flash card reader replacement: step 3, image 2 of 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
    Ask FixBot
  4. RCA Lyra X2400 flash card reader replacement: step 4, image 1 of 3 RCA Lyra X2400 flash card reader replacement: step 4, image 2 of 3 RCA Lyra X2400 flash card reader replacement: step 4, image 3 of 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
    Ask FixBot
  5. RCA Lyra X2400 flash card reader replacement, Motherboard: step 5, image 1 of 2 RCA Lyra X2400 flash card reader replacement, Motherboard: step 5, image 2 of 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
    Ask FixBot
  6. RCA Lyra X2400 flash card reader replacement, Compact Flash Card: step 6, image 1 of 2 RCA Lyra X2400 flash card reader replacement, Compact Flash Card: step 6, image 2 of 2
    • Locate the compact flash card slot on the logic board. For assistance on locating this component look at the picture to the left.
    • Use soldering/desoldering tools to remove the compact flash card.
    • Replace compact flash card and use soldering tools to complete the replacement.
    Ask FixBot
Joseph Goodwin
1 Reputation
5 Guides authored
Cal Poly, Team 17-3, Regan Spring 2013 Member of Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 66
All Time: 517
