RCA CC310 Onboard Microphone Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
96
All Time:
1,520
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will instruct you to replace the onboard microphone if it is faulty.
Parts
Tools
    1. RCA CC310 Onboard Microphone Replacement, Onboard Microphone: step 1, image 1 of 2 RCA CC310 Onboard Microphone Replacement, Onboard Microphone: step 1, image 2 of 2
      • Lift the metal flap and slide the viewfinder off to the right.
      Ask FixBot
    2. RCA CC310 Onboard Microphone Replacement: step 2, image 1 of 3 RCA CC310 Onboard Microphone Replacement: step 2, image 2 of 3 RCA CC310 Onboard Microphone Replacement: step 2, image 3 of 3
      • Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
      • Lift the plastic where the cable is connected to the viewfinder.
      • Disconnect the cable inside by pulling it apart.
      Ask FixBot
    3. RCA CC310 Onboard Microphone Replacement: step 3, image 1 of 2 RCA CC310 Onboard Microphone Replacement: step 3, image 2 of 2
      • Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
      • Lift the viewfinder plastic assembly up.
      Ask FixBot
    4. RCA CC310 Onboard Microphone Replacement: step 4, image 1 of 2 RCA CC310 Onboard Microphone Replacement: step 4, image 2 of 2
      • Lift the microphone circuit board straight up.
      • Unclip the cable connected to the circuit board.
      Ask FixBot
    5. RCA CC310 Onboard Microphone Replacement: step 5, image 1 of 1
      • Turn the microphone circuit board over.
      • Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
      Ask FixBot
    6. RCA CC310 Onboard Microphone Replacement: step 6, image 1 of 1
      • Desolder the metal protective housing using a soldering iron.
      • Desolder the microphone and replace it.
      Ask FixBot
Oliver Adams
629 Reputation
6 Guides authored
Cal Poly, Team 5-20, Amido Winter 2011 Member of Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 96
All Time: 1,520
