RCA CC310 Main Motherboard Replacement
  1. RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: step 1, image 1 of 2 RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: step 1, image 2 of 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
    Ask FixBot
  2. RCA CC310 Main Motherboard Replacement: step 2, image 1 of 2 RCA CC310 Main Motherboard Replacement: step 2, image 2 of 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
    Ask FixBot
  3. RCA CC310 Main Motherboard Replacement: step 3, image 1 of 2 RCA CC310 Main Motherboard Replacement: step 3, image 2 of 2
    • Pry along the seam on the top side near the buttons with a spudger.
    Ask FixBot
  4. RCA CC310 Main Motherboard Replacement: step 4, image 1 of 2 RCA CC310 Main Motherboard Replacement: step 4, image 2 of 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
    Ask FixBot
  5. RCA CC310 Main Motherboard Replacement, Main Motherboard: step 5, image 1 of 2 RCA CC310 Main Motherboard Replacement, Main Motherboard: step 5, image 2 of 2
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
    Ask FixBot
  6. RCA CC310 Main Motherboard Replacement: step 6, image 1 of 2 RCA CC310 Main Motherboard Replacement: step 6, image 2 of 2
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
    Ask FixBot
  7. RCA CC310 Main Motherboard Replacement: step 7, image 1 of 1
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
    Ask FixBot
Oliver Adams
629 Reputation
6 Guides authored
Cal Poly, Team 5-20, Amido Winter 2011 Member of Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 50
All Time: 3,348
