RCA CC310 Effect Button Circuit Board Replacement
  1. RCA CC310 Effect Button Circuit Board Replacement, Disassembling RCA CC310 Left Cover: step 1, image 1 of 2 RCA CC310 Effect Button Circuit Board Replacement, Disassembling RCA CC310 Left Cover: step 1, image 2 of 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
    Ask FixBot
  2. RCA CC310 Effect Button Circuit Board Replacement: step 2, image 1 of 2 RCA CC310 Effect Button Circuit Board Replacement: step 2, image 2 of 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
    Ask FixBot
  3. RCA CC310 Effect Button Circuit Board Replacement: step 3, image 1 of 2 RCA CC310 Effect Button Circuit Board Replacement: step 3, image 2 of 2
    • Pry along the seam on the top side near the buttons with a spudger.
    Ask FixBot
  4. RCA CC310 Effect Button Circuit Board Replacement: step 4, image 1 of 2 RCA CC310 Effect Button Circuit Board Replacement: step 4, image 2 of 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
    Ask FixBot
  5. RCA CC310 Effect Button Circuit Board Replacement, Effect Button Circuit Board: step 5, image 1 of 2 RCA CC310 Effect Button Circuit Board Replacement, Effect Button Circuit Board: step 5, image 2 of 2
    • Unplug the two cables on the bottom of the effect button circuit board.
    • Unplug the cable at the top left side of the motherboard.
    Ask FixBot
  6. RCA CC310 Effect Button Circuit Board Replacement: step 6, image 1 of 3 RCA CC310 Effect Button Circuit Board Replacement: step 6, image 2 of 3 RCA CC310 Effect Button Circuit Board Replacement: step 6, image 3 of 3
    • Pull the plastic tabs away from the circuit board.
    • Pull the board away from the camcorder.
    • Use a spudger to help push the mini-circuit board away from the camcorder at the same time.
    • Unplug the cable in the middle of the effects board.
    Ask FixBot
Oliver Adams
629 Reputation
6 Guides authored
Cal Poly, Team 5-20, Amido Winter 2011 Member of Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 37
All Time: 2,152
