Up to 20% off select tools
RCA 8 Apollo Volume Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
52
All Time:
362
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
If you noticed your volume buttons are not controlling your volume, and you have tried other methods of raising and lowering your volume, this guide will show you how to replace the volume buttons control pad.
    1. RCA 8 Apollo Volume Button Replacement, Back Panel: step 1, image 1 of 1
      • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your tablet before beginning to disassemble.
      Ask FixBot
    2. RCA 8 Apollo Volume Button Replacement: step 2, image 1 of 2 RCA 8 Apollo Volume Button Replacement: step 2, image 2 of 2
      • Insert an iFixit opening tool into the gap between the tablet and back panel.
      • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
      • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
      Ask FixBot
    3. RCA 8 Apollo Volume Button Replacement: step 3, image 1 of 2 RCA 8 Apollo Volume Button Replacement: step 3, image 2 of 2
      • Disconnect the red and black speaker wires from the tablet.
      • The front and back of the tablet will be disconnected.
      Ask FixBot
    1. RCA 8 Apollo Volume Button Replacement, Volume Button: step 4, image 1 of 1
      • The volume button control pad is located in the back panel, on the right side of the tablet.
      • Push on the outside of the volume button control pad and it will simply loosen and detach.
      Ask FixBot
Author
with
Brooke Still
123 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 52
All Time: 362
