Up to 20% off select tools
RCA 8 Apollo Display Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
67
All Time:
415
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or malfunctioning display on your RCA Apollo 8 tablet (identified with model number RCT6573W23).
The display assembly is the output component to present information and is made up of the glass panel, digitizer, and AMOLED display sandwiched together. Your display may need to be replaced if the glass cracks or is broken because this will affect its touch screen capabilities. It could also experience something called “screen burn-in” that happens on AMOLED displays. “Screen burn-in” is when some of the individual light-emitting pixels powering the display will dim the more they are used, causing uneven lighting and colors.
If your display is shattered, follow this guide to reinforce your screen to avoid injury until you replace the display. Make sure to power off your tablet completely and disconnect from any external power source prior to beginning this guide.
    1. RCA 8 Apollo Display Assembly Replacement, Back Panel: step 1, image 1 of 1
      • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your tablet before beginning to disassemble.
      Ask FixBot
    2. RCA 8 Apollo Display Assembly Replacement: step 2, image 1 of 2 RCA 8 Apollo Display Assembly Replacement: step 2, image 2 of 2
      • Insert an iFixit opening tool into the gap between the tablet and back panel.
      • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
      • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
      Ask FixBot
    3. RCA 8 Apollo Display Assembly Replacement: step 3, image 1 of 2 RCA 8 Apollo Display Assembly Replacement: step 3, image 2 of 2
      • Disconnect the red and black speaker wires from the tablet.
      • The front and back of the tablet will be disconnected.
      Ask FixBot
    1. RCA 8 Apollo Display Assembly Replacement, Display Assembly: step 4, image 1 of 3 RCA 8 Apollo Display Assembly Replacement, Display Assembly: step 4, image 2 of 3 RCA 8 Apollo Display Assembly Replacement, Display Assembly: step 4, image 3 of 3
      • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
      • Remove the yellow tape that is around the battery.
      • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
      • If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    2. RCA 8 Apollo Display Assembly Replacement: step 5, image 1 of 1
      • Remove the three screws from the motherboard using a Phillips screwdriver.
      Ask FixBot
    3. RCA 8 Apollo Display Assembly Replacement: step 6, image 1 of 1
      • Remove the battery and motherboard together from the tablet.
      • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
      • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
      Ask FixBot
Kristen Gismondi
110,399 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 67
All Time: 415
