Up to 20% off select tools
RCA 8 Apollo Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
58
All Time:
403
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the front or back camera on a RCA Apollo 8 tablet.
    1. RCA 8 Apollo Camera Replacement, Back Panel: step 1, image 1 of 1
      • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your tablet before beginning to disassemble.
      Ask FixBot
    2. RCA 8 Apollo Camera Replacement: step 2, image 1 of 2 RCA 8 Apollo Camera Replacement: step 2, image 2 of 2
      • Insert an iFixit opening tool into the gap between the tablet and back panel.
      • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
      • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
      Ask FixBot
    3. RCA 8 Apollo Camera Replacement: step 3, image 1 of 2 RCA 8 Apollo Camera Replacement: step 3, image 2 of 2
      • Disconnect the red and black speaker wires from the tablet.
      • The front and back of the tablet will be disconnected.
      Ask FixBot
    1. RCA 8 Apollo Camera Replacement, Display Assembly: step 4, image 1 of 3 RCA 8 Apollo Camera Replacement, Display Assembly: step 4, image 2 of 3 RCA 8 Apollo Camera Replacement, Display Assembly: step 4, image 3 of 3
      • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
      • Remove the yellow tape that is around the battery.
      • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
      • If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    2. RCA 8 Apollo Camera Replacement: step 5, image 1 of 1
      • Remove the three screws from the motherboard using a Phillips screwdriver.
      Ask FixBot
    3. RCA 8 Apollo Camera Replacement: step 6, image 1 of 1
      • Remove the battery and motherboard together from the tablet.
      • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
      • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
      Ask FixBot
    1. RCA 8 Apollo Camera Replacement, Camera: step 7, image 1 of 2 RCA 8 Apollo Camera Replacement, Camera: step 7, image 2 of 2
      • Remove the front facing and back facing cameras from the top of the tablet.
      Ask FixBot
Author
with
Chantel Pfiefer
219 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 58
All Time: 403
