Up to 20% off select tools
Quick-Fix: Replacing a Zipper Pull
Views: 20K
View statistics:
Past 24 Hours:
16
Past 7 Days:
125
Past 30 Days:
444
All Time:
20,238
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Introduction
Go to step 1 ↓
A missing or broken pull on a zipper can make life difficult when you try to open and close your Patagonia jacket. This guide will show you a quick-fix method you can use in the field or as an interim solution until you can replace your slider. Don't have a zipper pull? A loop of very thin cord or string will not only work, but make MacGuyver proud.
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 3 or under. Instead, we recommend return of the product for professional repair services.
For replacement parts or further assistance, contact Patagonia Customer Service.
Return to the Patagonia Care & Repair homepage.
    1. Quick-Fix: Replacing a Zipper Pull, Quick-Fix: Replacing a Zipper Pull: step 1, image 1 of 3 Quick-Fix: Replacing a Zipper Pull, Quick-Fix: Replacing a Zipper Pull: step 1, image 2 of 3 Quick-Fix: Replacing a Zipper Pull, Quick-Fix: Replacing a Zipper Pull: step 1, image 3 of 3
      • Grab your zipper pull.
      • Thread the cord of the zipper pull through the hole on the slider where the pull used to be.
      Ask FixBot
    2. Quick-Fix: Replacing a Zipper Pull: step 2, image 1 of 2 Quick-Fix: Replacing a Zipper Pull: step 2, image 2 of 2
      • Make a loop with the cord that has passed through the hole.
      • Feed the rubber end through the loop.
      Ask FixBot
    3. Quick-Fix: Replacing a Zipper Pull: step 3, image 1 of 3 Quick-Fix: Replacing a Zipper Pull: step 3, image 2 of 3 Quick-Fix: Replacing a Zipper Pull: step 3, image 3 of 3
      • Pull the rubber part through the loop, then pull it tight.
      Ask FixBot
Finish Line
5 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 125
Past 30 Days: 444
All Time: 20,238
