Up to 20% off select tools
Quick way to test LEDs
Views: 2.6K
View statistics:
Past 24 Hours:
33
Past 7 Days:
167
Past 30 Days:
462
All Time:
2,650
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. Quick way to test LEDs, Quick way to test an LED: step 1, image 1 of 3 Quick way to test LEDs, Quick way to test an LED: step 1, image 2 of 3 Quick way to test LEDs, Quick way to test an LED: step 1, image 3 of 3
      • In most Christmas light strands that I have seen, the LEDs are inserted into a plug and the plug goes into a socket on the strand. If one (or more)LEDs is bad, an entire section of the strand will not light up.
      Ask FixBot
      • Previously I have suggested finding a known good LED from a section that works, and using it to replace each LED in the bad section, one by one, to see if it lights up, thus identifying the bad one. This only works if one and only one LED is bad, however. And it's tedious.
      Ask FixBot
    2. Quick way to test LEDs, Easier method: step 3, image 1 of 3 Quick way to test LEDs, Easier method: step 3, image 2 of 3 Quick way to test LEDs, Easier method: step 3, image 3 of 3
      • An easier way: press one side of a coin battery to one of the LED leads (still in the plug), and then use a pair of metal pliers to simultaneously touch the other lead to the OTHER side of the battery. The piers act as a conductor to complete the circuit. If it doesn't work, also try turning the battery over- LEDs only conduct in one direction.
      Ask FixBot
      • Any 3V coin battery will do. If the LED doesn't light up with the battery in either direction, then it is bad- replace it.
      Ask FixBot
    3. Quick way to test LEDs, Great way to test LED Christmas Lights: step 5, image 1 of 1
      • The pliers were too difficult for me so I taped wires to the button battery and use a clothespin to hold the bulb.
      Ask FixBot
2 other people completed this guide.
Author
with
Betty Lise
752 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 33
Past 7 Days: 167
Past 30 Days: 462
All Time: 2,650
