Up to 20% off select tools
Quick Antenna Connection Check for Delphi MyFi XM2GO
Views: 3.7K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
87
All Time:
3,748
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • Spudger
    4.9
    1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: step 1, image 1 of 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: step 1, image 2 of 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: step 1, image 3 of 3
      • Locate the large button on the top of the device.
      • Push down on the button and slide the cover away from the button.
      • The battery removal tab may pop up.
      Ask FixBot
    1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: step 2, image 1 of 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: step 2, image 2 of 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: step 2, image 3 of 3
      • Grab the red pull tab and pull down to unlock the latch.
      • Pull the battery out.
      Ask FixBot
    1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Quick Antenna Connection Check for Delphi MyFi XM2GO: step 3, image 1 of 1
      • Under the battery is a magnetic mat, shown in red, that shields battery interference with the reception of the XM Satellite antenna.
      • This mat is stuck to the back of the device like a sticker and can be removed.
      • CAUTION: Do not operate the device without this magnetic shield.
      Ask FixBot
    2. Quick Antenna Connection Check for Delphi MyFi XM2GO: step 4, image 1 of 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: step 4, image 2 of 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: step 4, image 3 of 3
      • On the bottom left side of the magnetic mat, the corner can be lifted up to reveal the U.FL antenna connector. A spudger or your fingernails can be used to pry up the corners.
      • These U.FL antenna connections are standard for most portable devices and WiFi cards. They may become detached through use and may be checked if no reception is present.
      • Lift up the corner and notice the two connectors going to the PCB.
      Ask FixBot
    3. Quick Antenna Connection Check for Delphi MyFi XM2GO: step 5, image 1 of 2 Quick Antenna Connection Check for Delphi MyFi XM2GO: step 5, image 2 of 2
      • Both of these connectors must be firmly attached to the PCB. Try pressing them firmly to make sure they are making full contact.
      Ask FixBot
    4. Quick Antenna Connection Check for Delphi MyFi XM2GO: step 6, image 1 of 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: step 6, image 2 of 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: step 6, image 3 of 3
      • On the top right corner, the magnetic mat can be lifted up to check another U.FL connector as with the 3rd step.
      • This mat can be pressed down again to secure after checking the connector.
      Ask FixBot
    5. Quick Antenna Connection Check for Delphi MyFi XM2GO: step 7, image 1 of 1
      • Try pressing down on the U.FL connector, as seen in this picture, to ensure a secure connection.
      Ask FixBot
Author
with
Scott Byer
88 Reputation
5 Guides authored
Clemson, Team 1-2, Benson Spring 2012 Member of Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Members
108 Guides authored
1 Guide Comment
la radio sigue sin funcionar
luis - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 87
All Time: 3,748
