Quantum View 10.1 Battery Replacement
  1. Quantum View 10.1 Battery Replacement, Open Quantum View case: step 1, image 1 of 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: step 2, image 1 of 2 Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: step 2, image 2 of 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Battery Replacement, Unhooking the battery: step 3, image 1 of 2 Quantum View 10.1 Battery Replacement, Unhooking the battery: step 3, image 2 of 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
4 Guide Comments
How do I find a replacement battery?
Chris Clayton - Reply Share
Seems finding the right battery is a problem
where can I find a replacement battery and screen for this i only have the motherboard lying around and i really want to repair it so i can access old data
aabel joby - Reply Share
the only way is to desolder the old bms from the battery and solder a new battery with the same dimensions, voltage, capacity etc. they are easy to find on aliexpress, i replaced my battery this way, but be very careful with batteries, or if you have enough soldering skills you can solder a usb connector to the barrel jack on the motherboard for a quick fix, gonna try this myself later
if you have the original power supply you can use it, also this tablet doesnt support charging trough micro usb, its for data only
mishaneyu - Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 32
All Time: 1,272
