Qualcomm QCP-2760 Screen Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
16
Past 30 Days:
95
All Time:
882
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Screen will remove with motherboard. Follow prerequisites to motherboard removal.
Tools
    1. Qualcomm QCP-2760 Screen Replacement, Battery: step 1, image 1 of 1
      • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
      • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
      Ask FixBot
    1. Qualcomm QCP-2760 Screen Replacement, Rear Backing: step 2, image 1 of 2 Qualcomm QCP-2760 Screen Replacement, Rear Backing: step 2, image 2 of 2
      • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
      • Find the seam between the front and back of the phone
      • Pry the seam open using a plastic opening tool, or your fingers.
      • Some force is required
      Ask FixBot
    1. Qualcomm QCP-2760 Screen Replacement, Motherboard: step 3, image 1 of 1
      • Locate the four metal clips holding the motherboard onto the phone.
      • Pull the clips away from the motherboard while lifting the motherboard out of the case.
      • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
      Ask FixBot
    2. Qualcomm QCP-2760 Screen Replacement: step 4, image 1 of 2 Qualcomm QCP-2760 Screen Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Place the motherboard down so that the screen is facing up.
      • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
      • Locate, but do not disconnect, the four screen clips.
      Ask FixBot
    3. Qualcomm QCP-2760 Screen Replacement: step 5, image 1 of 2 Qualcomm QCP-2760 Screen Replacement: step 5, image 2 of 2
      • Flip the motherboard over so that the screen is facing down.
      • Again, be careful not to put stress on the speaker cable.
      Ask FixBot
    1. Qualcomm QCP-2760 Screen Replacement, Screen: step 6, image 1 of 1
      • Use your fingers to pull back the clear plastic clips
      • The clips are fragile. Use caution when removing screen.
      Ask FixBot
Xavier
313 Reputation
3 Guides authored
Ohio State, Team 1-4, Buehl Fall 2014 Member of Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 95
All Time: 882
