Qualcomm QCP-2760 Motherboard Replacement
  1. Qualcomm QCP-2760 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
    Ask FixBot
  2. Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: step 2, image 1 of 2 Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: step 2, image 2 of 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
    Ask FixBot
  3. Qualcomm QCP-2760 Motherboard Replacement, Motherboard: step 3, image 1 of 1
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
    Ask FixBot
  4. Qualcomm QCP-2760 Motherboard Replacement: step 4, image 1 of 2 Qualcomm QCP-2760 Motherboard Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
    Ask FixBot
  5. Qualcomm QCP-2760 Motherboard Replacement: step 5, image 1 of 2 Qualcomm QCP-2760 Motherboard Replacement: step 5, image 2 of 2
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
    Ask FixBot
Graham
107 Reputation
1 Guide authored
Ohio State, Team 1-4, Buehl Fall 2014 Member of Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 33
All Time: 553
