QSEW QS-1201 Needle Replacement
  1. QSEW QS-1201 Needle Replacement, Needle: step 1, image 1 of 3 QSEW QS-1201 Needle Replacement, Needle: step 1, image 2 of 3 QSEW QS-1201 Needle Replacement, Needle: step 1, image 3 of 3
    • Power off your machine and unplug it from the outlet.
    • This will prevent accidental activation and injury, even for experts!
    Ask FixBot
  2. QSEW QS-1201 Needle Replacement: step 2, image 1 of 2 QSEW QS-1201 Needle Replacement: step 2, image 2 of 2
    • Have a close look at the difference between the broken needle ( left ) and the brand-new needle ( right ).
    Ask FixBot
  3. QSEW QS-1201 Needle Replacement: step 3, image 1 of 3 QSEW QS-1201 Needle Replacement: step 3, image 2 of 3 QSEW QS-1201 Needle Replacement: step 3, image 3 of 3
    • Locate the needle holder with the broken needle.
    Ask FixBot
  4. QSEW QS-1201 Needle Replacement: step 4, image 1 of 3 QSEW QS-1201 Needle Replacement: step 4, image 2 of 3 QSEW QS-1201 Needle Replacement: step 4, image 3 of 3
    Tool used on this step:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Buy
    Ask FixBot
  5. QSEW QS-1201 Needle Replacement: step 5, image 1 of 3 QSEW QS-1201 Needle Replacement: step 5, image 2 of 3 QSEW QS-1201 Needle Replacement: step 5, image 3 of 3
    • Gently secure the needle with the needle nose pliers.
    • With a tight grip, pull down to remove the needle.
    Ask FixBot
  6. QSEW QS-1201 Needle Replacement: step 6, image 1 of 3 QSEW QS-1201 Needle Replacement: step 6, image 2 of 3 QSEW QS-1201 Needle Replacement: step 6, image 3 of 3
    • Discard the broken needle in a safe place.
    • By doing so, you ensure that no one gets injured when dealing with the trash.
    • Afterward, use the needle nose pliers to insert the new needle into the needle holder securely.
    Ask FixBot
  7. QSEW QS-1201 Needle Replacement: step 7, image 1 of 3 QSEW QS-1201 Needle Replacement: step 7, image 2 of 3 QSEW QS-1201 Needle Replacement: step 7, image 3 of 3
    • Use the 3 mm Flathead screwdriver to secure the screw, without over-tightening.
    Ask FixBot
  8. QSEW QS-1201 Needle Replacement: step 8, image 1 of 3 QSEW QS-1201 Needle Replacement: step 8, image 2 of 3 QSEW QS-1201 Needle Replacement: step 8, image 3 of 3
    • Move the needle using the pliers in a circular motion from left to right to verify it moves freely without hitting any surrounding components.
    • You're all set to use your embroidery machine!
    Ask FixBot
Reema
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 39
All Time: 716
