QFX IT-437 Motherboard Replacement
    1. QFX IT-437 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Begin the process by using a PH00 Phillips screw driver.
      • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
      Ask FixBot
    2. QFX IT-437 Motherboard Replacement: step 2, image 1 of 2 QFX IT-437 Motherboard Replacement: step 2, image 2 of 2
      • Use the iFixit plastic opening tool to pry open the back of the tablet.
      • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
      Ask FixBot
    3. QFX IT-437 Motherboard Replacement: step 3, image 1 of 1
      • In order to unseat the motherboard, use the Phillips PH00 screw driver bit to remove the three 1.2mm x 3mm screws.
      Ask FixBot
    4. QFX IT-437 Motherboard Replacement: step 4, image 1 of 1
      • Once the motherboard is loose, remove the tape above the SD card slot using an iFixit opening pick.
      • Be careful not to rip or damage the tape or else new tape will have to be used for the new motherboard.
      Ask FixBot
    5. QFX IT-437 Motherboard Replacement: step 5, image 1 of 1
      • Use the spudger to remove the ribbon.
      • Avoid using too much force here or else the ribbon can be ripped.
      Ask FixBot
    6. QFX IT-437 Motherboard Replacement: step 6, image 1 of 1
      • Use the spudger in the top corner of the tablet and lift the camera up.
      Ask FixBot
    7. QFX IT-437 Motherboard Replacement: step 7, image 1 of 1
      • Lift the tape over the wires that are holding them to the tablet insulation.
      Ask FixBot
    8. QFX IT-437 Motherboard Replacement: step 8, image 1 of 1
      • Pull out the motherboard and set it aside.
      • The wires must be soldered back on to the motherboard.
      Ask FixBot
2 other people completed this guide.
Douglas
482 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 477
