QFX IT-437 Camera Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
85
All Time:
455
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide shows what's involved and the how-to in replacing the camera on the tablet device.
Tools
    1. QFX IT-437 Camera Assembly Replacement, Camera Assembly: step 1, image 1 of 1
      • Begin the process by using a PH00 Phillips screw driver.
      • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
      Ask FixBot
    2. QFX IT-437 Camera Assembly Replacement: step 2, image 1 of 2 QFX IT-437 Camera Assembly Replacement: step 2, image 2 of 2
      • Use the iFixit plastic opening tool to pry open the back of the tablet.
      • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
      Ask FixBot
    3. QFX IT-437 Camera Assembly Replacement: step 3, image 1 of 1
      • Use the spudger to unhinge the camera from its socket.
      Ask FixBot
    4. QFX IT-437 Camera Assembly Replacement: step 4, image 1 of 1
      • Use the plastic opening pick and the Phillips screwdriver to remove the camera from its soldering on the motherboard, and set it aside to be replaced.
      Ask FixBot
Douglas
482 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 85
All Time: 455
