Up to 20% off select tools
QFX IT-437 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
81
All Time:
901
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. QFX IT-437 Battery Replacement, Battery: step 1, image 1 of 1
      • Begin the process by using a PH00 Phillips screw driver.
      • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
      Ask FixBot
    2. QFX IT-437 Battery Replacement: step 2, image 1 of 2 QFX IT-437 Battery Replacement: step 2, image 2 of 2
      • Use the iFixit plastic opening tool to pry open the back of the tablet.
      • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
      Ask FixBot
    3. QFX IT-437 Battery Replacement: step 3, image 1 of 1
      • Remove the tape connecting the battery to the motherboard.
      • Save the tape in good condition for the replacement so the wires do not get stuck in the case.
      Ask FixBot
    4. QFX IT-437 Battery Replacement: step 4, image 1 of 1
      • Remove the black tape attaching the wires to the battery.
      Ask FixBot
    5. QFX IT-437 Battery Replacement: step 5, image 1 of 1
      • Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
      • The removed wires will have to be soldered back on to the motherboard.
      Ask FixBot
Author
with
Douglas
482 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 81
All Time: 901
