Up to 20% off select tools
Pyrus PY21S03211 Display Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
99
All Time:
958
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
Display screens can break from falls or scratches. Instead of purchasing a new device, replacing the screen is far more inexpensive. It's very important to keep both the large white connector and the gold connector from being pulled or torn, so keep the side panel close to the motherboard when first opening the device.
If the display on your Pyrus PY21S03211 video camera is broken, follow this guide to replace it.
Before you begin, make sure that the camera is off and unplugged from the charger. Also, make sure to remove the battery.
    1. Pyrus PY21S03211 Display Screen Replacement, Display Screen: step 1, image 1 of 3 Pyrus PY21S03211 Display Screen Replacement, Display Screen: step 1, image 2 of 3 Pyrus PY21S03211 Display Screen Replacement, Display Screen: step 1, image 3 of 3
      • Find the tab at the bottom covering the battery compartment.
      • Pull back the tab to reveal the battery compartment.
      Ask FixBot
    2. Pyrus PY21S03211 Display Screen Replacement: step 2, image 1 of 1
      • To remove the battery from the device, pull back the tab holding it in place and then remove the battery.
      Ask FixBot
    3. Pyrus PY21S03211 Display Screen Replacement: step 3, image 1 of 2 Pyrus PY21S03211 Display Screen Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Open up the display screen.
      • Remove the tab covering the battery compartment using a pair of tweezers.
      Ask FixBot
    4. Pyrus PY21S03211 Display Screen Replacement: step 4, image 1 of 2 Pyrus PY21S03211 Display Screen Replacement: step 4, image 2 of 2
      • Use a #00 screwdriver to remove all six 4 mm screws from the side of the device.
      Ask FixBot
    5. Pyrus PY21S03211 Display Screen Replacement: step 5, image 1 of 2 Pyrus PY21S03211 Display Screen Replacement: step 5, image 2 of 2
      • To remove the side face of the device, you can use a plastic pick to gently pry it off. Be careful while doing so to avoid potential device damage.
      Ask FixBot
    6. Pyrus PY21S03211 Display Screen Replacement: step 6, image 1 of 1
      • Carefully open the side face. Keep the side face close to the body of the device to avoid pulling on the white wires.
      Ask FixBot
    7. Pyrus PY21S03211 Display Screen Replacement: step 7, image 1 of 2 Pyrus PY21S03211 Display Screen Replacement: step 7, image 2 of 2
      • To remove the side face completely, locate the big white connector.
      • Lift the grey lip using tweezers. Then, carefully take out the white connector.
      Ask FixBot
    8. Pyrus PY21S03211 Display Screen Replacement: step 8, image 1 of 3 Pyrus PY21S03211 Display Screen Replacement: step 8, image 2 of 3 Pyrus PY21S03211 Display Screen Replacement: step 8, image 3 of 3
      • Set the device down with the screen facing towards you.
      • Remove the four 4mm silver screws from the back of the side face.
      Ask FixBot
    9. Pyrus PY21S03211 Display Screen Replacement: step 9, image 1 of 2 Pyrus PY21S03211 Display Screen Replacement: step 9, image 2 of 2
      • Use tweezers to remove the small shiny black plastic corner piece from the side.
      Ask FixBot
    10. Pyrus PY21S03211 Display Screen Replacement: step 10, image 1 of 3 Pyrus PY21S03211 Display Screen Replacement: step 10, image 2 of 3 Pyrus PY21S03211 Display Screen Replacement: step 10, image 3 of 3
      • Twist the screen to the side to reveal two black 4mm screws.
      • Remove screws from both sides of the screen.
      Ask FixBot
    11. Pyrus PY21S03211 Display Screen Replacement: step 11, image 1 of 2 Pyrus PY21S03211 Display Screen Replacement: step 11, image 2 of 2
      • Use a plastic pick to pry off the backside of the screen.
      Ask FixBot
    12. Pyrus PY21S03211 Display Screen Replacement: step 12, image 1 of 2 Pyrus PY21S03211 Display Screen Replacement: step 12, image 2 of 2
      • Use tweezers to open the gray lip of the large white connector and carefully remove it.
      Ask FixBot
    13. Pyrus PY21S03211 Display Screen Replacement: step 13, image 1 of 1
      • Find two 4mm silver screws at the base of the screen and remove them.
      Ask FixBot
    14. Pyrus PY21S03211 Display Screen Replacement: step 14, image 1 of 1
      • To remove the gold transparent connector, gently flip open the grey lip using tweezers.
      Ask FixBot
    15. Pyrus PY21S03211 Display Screen Replacement: step 15, image 1 of 1
      • Locate the two 4mm black screw on top of the display screen and remove them.
      Ask FixBot
    16. Pyrus PY21S03211 Display Screen Replacement: step 16, image 1 of 2 Pyrus PY21S03211 Display Screen Replacement: step 16, image 2 of 2
      • Remove green board carefully.
      Ask FixBot
    17. Pyrus PY21S03211 Display Screen Replacement: step 17, image 1 of 3 Pyrus PY21S03211 Display Screen Replacement: step 17, image 2 of 3 Pyrus PY21S03211 Display Screen Replacement: step 17, image 3 of 3
      • Gently remove the white display screen with your hands.
      Ask FixBot
    18. Pyrus PY21S03211 Display Screen Replacement: step 18, image 1 of 1
      • Carefully insert the replacement screen.
      Ask FixBot
Author
with
Danielle Hadaway
255 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 99
All Time: 958
