Pyle Astro PTBL7C LCD Replacement
    1. Pyle Astro PTBL7C LCD Replacement, LCD: step 1, image 1 of 2 Pyle Astro PTBL7C LCD Replacement, LCD: step 1, image 2 of 2
      • Using the plastic opening tool, work your way along the edge of the tablet.
      • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
      • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
      • Place the front display assembly facing front side down to expose the inside.
      Ask FixBot
    2. Pyle Astro PTBL7C LCD Replacement: step 2, image 1 of 2 Pyle Astro PTBL7C LCD Replacement: step 2, image 2 of 2
      • Remove the three 4 mm JIS #0 screws to release the PCB board.
      Ask FixBot
    3. Pyle Astro PTBL7C LCD Replacement: step 3, image 1 of 1
      • The display is held in place by plastic tabs which slide over the outer edges of the backside of the display.
      • Gently work your way around the display while pulling the plastic tabs back to release the LCD display from the front panel.
      Ask FixBot
    4. Pyle Astro PTBL7C LCD Replacement: step 4, image 1 of 1
      • Once all clips are released gently open and separate the front plastic display from the LCD and place the LCD face down.
      • The front plastic display contains the external touch panel, and the capacitive touch screen overlay.
      Ask FixBot
    5. Pyle Astro PTBL7C LCD Replacement: step 5, image 1 of 1
      • Using both hands, gently release the ribbon cable to the capacitive touch screen overlay from the PCB board by pushing both gray tabs outwards.
      Ask FixBot
    6. Pyle Astro PTBL7C LCD Replacement: step 6, image 1 of 1
      Ask FixBot
    7. Pyle Astro PTBL7C LCD Replacement: step 7, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Using a plastic card, gently remove the adhesive that holds the battery in place and separate the battery from the LCD panel.
      • Exercise extreme caution and be sure to not rupture the battery casing.
      Ask FixBot
    8. Pyle Astro PTBL7C LCD Replacement: step 8, image 1 of 1
      Ask FixBot
Andrew Redifer
265 Reputation
2 Guides authored
IUPUI, Team S3-G6, Harley Spring 2018 Member of IUPUI, Team S3-G6, Harley Spring 2018
IUPUI-HARLEY-S18S3G6
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 649
