Up to 20% off select tools
Purple SmartVP Light Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
74
All Time:
600
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Purple SmartVP Light Replacement, Light: step 1, image 1 of 3 Purple SmartVP Light Replacement, Light: step 1, image 2 of 3 Purple SmartVP Light Replacement, Light: step 1, image 3 of 3
      • Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component.
      Ask FixBot
    2. Purple SmartVP Light Replacement: step 2, image 1 of 2 Purple SmartVP Light Replacement: step 2, image 2 of 2
      • Remove the 1.2 cm hex T9 screws and gently open up the device.
      Ask FixBot
    3. Purple SmartVP Light Replacement: step 3, image 1 of 2 Purple SmartVP Light Replacement: step 3, image 2 of 2
      • Flip the top bar over and using a #00 phillips head screwdriver, remove the five 7mm screws holding the bar together.
      Ask FixBot
    4. Purple SmartVP Light Replacement: step 4, image 1 of 2 Purple SmartVP Light Replacement: step 4, image 2 of 2
      • Carefully pry off the plastic panel, revealing the motherboard.
      Ask FixBot
    5. Purple SmartVP Light Replacement: step 5, image 1 of 2 Purple SmartVP Light Replacement: step 5, image 2 of 2
      • Remove the two 7mm screws holding the motherboard in place with a phillips head screwdriver size #00.
      Ask FixBot
    6. Purple SmartVP Light Replacement: step 6, image 1 of 2 Purple SmartVP Light Replacement: step 6, image 2 of 2
      • To release the motherboard from its plastic housing, first pull the plastic light covers up and away from the device.
      Ask FixBot
    7. Purple SmartVP Light Replacement: step 7, image 1 of 2 Purple SmartVP Light Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Heat the solder on the underside of the affected light to remove and replace it using tweezers.
      • Check out this helpful guide for some soldering and desoldering tips.
      Ask FixBot
Author
with
Brian Maulucci
579 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 74
All Time: 600
