Up to 20% off select tools
Purple SmartVP Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
74
All Time:
763
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Purple SmartVP Camera Replacement, Camera: step 1, image 1 of 2 Purple SmartVP Camera Replacement, Camera: step 1, image 2 of 2
      • Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component.
      Ask FixBot
    2. Purple SmartVP Camera Replacement: step 2, image 1 of 2 Purple SmartVP Camera Replacement: step 2, image 2 of 2
      • Remove the 1.2 cm hex T9 screws and gently open up the device.
      Ask FixBot
    3. Purple SmartVP Camera Replacement: step 3, image 1 of 2 Purple SmartVP Camera Replacement: step 3, image 2 of 2
      • Detach the camera cover from the motherboard. Be very careful to not damage any of the components on the motherboard.
      Ask FixBot
    4. Purple SmartVP Camera Replacement: step 4, image 1 of 2 Purple SmartVP Camera Replacement: step 4, image 2 of 2
      • Use a plastic spudger to push the black sliding cable connector away from the white bracket.
      Ask FixBot
    5. Purple SmartVP Camera Replacement: step 5, image 1 of 1
      • Gently remove the ribbon cable from the connector.
      Ask FixBot
Author
with
Brian Maulucci
579 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 74
All Time: 763
