Puritan Bennett 840 Oxygen Sensor Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Puritan Bennett 840 Oxygen Sensor Replacement, Oxygen Sensor: step 1, image 1 of 1
    • Locate the flexible oxygen sensor access cover on the top edge of the cabinet and firmly push the center of the lower flap of the access cover until the lower flap is dislodged from the cabinet.
    Ask FixBot
  2. Puritan Bennett 840 Oxygen Sensor Replacement: step 2, image 1 of 1
    • Pinch the bottom and top flaps of the access cover firmly together and pull the access cover away from the cabinet to remove.
    Ask FixBot
  3. Puritan Bennett 840 Oxygen Sensor Replacement: step 3, image 1 of 1
    • Press the small white release tab away from the sensor cable connector to release the sensor cable connector.
    • While continually pressing the release tab, gently pull the connector from the oxygen sensor.
    Ask FixBot
  4. Puritan Bennett 840 Oxygen Sensor Replacement: step 4, image 1 of 1
    • Unscrew (counter-clockwise) and remove the oxygen sensor.
    Ask FixBot
  5. Puritan Bennett 840 Oxygen Sensor Replacement: step 5, image 1 of 1
    • Open the replacement oxygen sensor and O-ring. Make sure the O-ring is at the threaded base of the oxygen sensor, and screw (clockwise) until snug.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Calibrate new oxygen sensor by pressing 100% O2/ CAL 2 min key. Run an SST to check the system before using the ventilator on a patient.
2 other people completed this guide.
Gabrielle Reyes
154 Reputation
1 Guide authored
Cal Poly, Team S7-G4, Paton Spring 2020 Member of Cal Poly, Team S7-G4, Paton Spring 2020
CPSU-PATON-S20S7G4
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 57
All Time: 2,552
